Methods for parallel propeller synchronization.
Clock Loop
This is a pretty big topic, and I hope people are willing to talk about their circuits, methods and programming, even tho, this is really the key to unlimited propeller power, as SOME have already taken advantage of. I.E. products that are only possible with multiple propellers running synchronized.
(scopes, gaming systems, etc...)
I had thought about it and most of my methods involve complex programming, which require a scope, and or timing diagrams written at the assembly level.
Anyone come up with an easy method?
TERMS OF USE: MIT License
"Permission is hereby granted, free of charge, to any pers...........................
..............................OMITTED FOR FORUM...............................................
.................. OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN THE SOFTWARE. "
All such schemes are going to have some synchronization latency, and it is the application that will determine how acceptable that is. In most apps offloading the user interface to something that isn't immediately updated will not cause trouble because human senses are slower than the interface latency. Robotic controls that might have timing critical responses to unpredictable real-world inputs would pose the biggest challenges.
I have been looking at the use of an external SPI RAM chip shared by multiple Props which take turns reading and writing to it; this has the advantage of not tying up a cog 100% of the time for communication. The props would still need an external way of making sure only one of them tries communicating with the RAM chip at a time.
cmapspublic3.ihmc.us:80/servlet/SBReadResourceServlet?rid=1181572927203_421963583_5511&partName=htmltext
Hello Rest Of The World
Hello Debris
Install a propeller and blow them away
en.wikipedia.org/wiki/Communicating_Sequential_Processes
CSP were the basis for the Inmos transputer, and live on in the XMOS devices (both designed by David May). They have special hardware on the chip for synchronizing processes and communication channels, but something similar could be implemented in software.
Leon
Amateur radio callsign: G1HSM
Suzuki SV1000S motorcycle
Post Edited (Leon) : 6/21/2009 5:13:33 PM GMT
Hello Debris
Leon
Hello Debris
There are indeed many reasons to connect multiple props, since the prop is an extremely cheap solution to a number of normally expensive problems. But if your application requires mroe than 8 cogs or 32 I/O lines you will need more than one. This isn't so unusual once you start applying the prop to industrial applications, and the other solutions are FAR more expensive.
Some applications will simply be tolerant of latency, such as user interfaces. (I will soon be designing a machine which will probably use one prop for the video, keyboard, touchscreen, and SD card interfaces, and another for a whole bunch of high speed machine timing; the interface between the two can be quite loose.) Others may have fixed windows, for example if a drive shaft rotates past a sensor you have a certain amount of time during which that can't possibly happen again, which you can use for sync comms. Others simply need to be done all on one bus, and with the prop that means one chip. I'm thinking of some high speed bagging and sorting applications where there are a lot of high speed I/O's going on and distributed decision making, such as systems with 8 scales that are constantly batching and then taking the best 3 of 8 to fill a single bag to generally get closer than one piece to the bag target weight. A lot of those things have 60 to 100 I/O's and they are making decisions on a millisecond basis as product and bags fly down conveyor belts and scales fill and are emptied. If it hiccups at the wrong time you end up with food on the floor.
Things like CSP are elegant and useful for things like avionics which must be absolutely reliable, and totally irrelevant to things like the prop where you don't have room for the implementation overhead and you're using the chip because it does $200 worth of work for $8. The prop isn't a supercomputer, it is an extremely cheap computing element that does certain previously very expensive things, like generating video, very elegantly and cheaply. It achieves this capability by making certain sacrifices, such as the 32K hub RAM limit and lack of external expandability, which require us to approach every application the way we approached them back around 1980. You need a certain amount of insight and cleverness to make it do anything useful at all; there are no one size fits all solutions. But when you do make it fit, you can get a lot done for eight bucks.
Leon
Post Edited (Leon) : 6/21/2009 8:57:20 PM GMT
I don't agree that it irrelevant to things like the Prop. Think how wonderfully useful it would be if one cog could write a LONG (say) to a special register or using a special instruction (wrchan) and that long was available to another COG (rdchan) as fast as silicon can allow via some COG-COG channel mechanism.
There are countless uses for such high speed links and that is CSP.
I've been campaigning for such on the Prop II. Not sure if anyone has noticed though.
Hello Debris
Leon
Post Edited (Leon) : 6/21/2009 9:35:59 PM GMT
I've done a lot of work on platforms with limitations similar to the P1, and I'll maintain that in RL applications there will almost always be an application specific approach that is faster and leaner than any reasonably universal approach. When you have a megabyte of RAM instead of 32K and 128 pins of I/O instead of 32 you can start thinking about universal plug-in protocols that do it all for everybody in all situations. As it is I find myself hacking bits out of things like the TVTEXT object that I don't need in order to fit in things I do.
Perhaps the Turbulence demo is a good example of why COG-COG links might be a good idea. LUFT obviously saw the need for it.
Transputers and now XMOS chips make good use of these ideas without megabytes of RAM and using quite simple mechanisms.
Leon
Hello Debris
This master prop resets, and makes the clock for the slave props.
Instead of programming delays, communications, etc..
I thought about using a feedback clock that runs from each slave prop to the master prop.
This feedback clock is 5mhz, and is generated on the slave prop.
The master prop also generates a 5mhz clock for that same slave prop.
The master prop counts the feedback clock of all the slave chips individually, and determines which prop is the slowest, and which the fastest.
Then this master prop adjusts the clocks of all the other props to match one of the slave props.
So for a bit the master prop over or under clocks the too fast or too slow props, at the same time counting the feedback clocks of each prop to determine where each prop is in its program.
So bascially its like the master prop is controlling the throttle of all the slave props, and starts counting the feedback clock from each prop, to determine where in its program it is, and adjusts the clock to synch it up.
This is something I was thinking of doing at initial start, because we all know that the prop won't act normal when its clock is being changed.
The master prop would require all the timing code, but each slave prop would only require the bootup synch.
This method might be more complicated than its worth, I don't know, but its still something I would like to try. I am sure there are issues to this method that I can't think of right now.
(the attached image is the circuit. The two slave props on the right are not fully connected)
Post Edited (Clock Loop) : 6/21/2009 11:42:10 PM GMT
Leon
Post Edited (Leon) : 6/22/2009 12:01:37 AM GMT
The hub will still affect the sync by cycles but you can determine each cog within the scheme of things.
· Home of the MultiBladeProps: TriBladeProp, RamBlade, TwinBlade,·SixBlade, website
· Emulators: Micros eg Altair, and Terminals eg VT100 (Index) ZiCog (Z80), MoCog (6809)
Fixated? Well for the fame, glory, and bragging rights of coarse... lol..
No app in mind, just didn't see much here about how one would go about accomplishing this.
Even my "messy" method might have some merit. Considering that the other methods discussed here involve precise assembly and spin.
To do proper synch, one would require a scope.
I am just trying to find ways to accomplish synch without having to resort to using assembly/spin programmed delays and a scope.
Plus if one WANTED to have different programs run on each prop, if the clocks were synched, and counted, the master prop would know how far into the program it is.
Even if programmed delays were put on one slave prop and not the other, the master prop would still have the feedback clock to count how "long" that particular prop was running..
Without even communicating with it.
Thats a pretty big deal, not having to communicate with a prop to figure out where it is in its program?
Messy, perhaps, but a new idea.. we need more.
Actually I see my idea as pretty interesting. I'll try it someday.
Leon
CSP is just a language to allow communication to do synch, if I understand it correctly.
I guess what I am getting at is keep as much as possible in hardware, to minimize the software overhead of doing the synch.
Using a single central clock would help, but then you can't adjust the clocks of the other chips to bring them into synch.
I guess I like the idea of NOT having to mess with a program to get it synched up. (communications)
Having the slave clock out a 5mhz signal is done easily by the props hardware no major programming involved, set it and forget it.
I like the idea of having a centralized prop that is the "DJ" who spins all the props into a synchronized song of many players. Players that don't even need to know about eachother, or communicate.
I mean if a central prop knows exacly where its slaves are, then that central prop can MOVE the PROGRAM to a different SYNCH spot, on the fly, by doing nothing more than adjusting the main clock of that slave.
I am sure there are limitations to changing the clock input of a prop. Like an upper and lower limit
before the program/prop/pll has an error.
This would be basically putting a PWM into the XI of the prop. But with limitations on upper and lower freq, plus duty cycle limitations.
Post Edited (Clock Loop) : 6/22/2009 1:26:30 AM GMT
After a delay to ensure all props are running, the master pulses a line low. When a cog in each prop (waitpeq) detects this line going low they read the CNT register. This then provides the starting point for each prop. They can then be synchronised to this counter - it wraps about every 90 seconds.
Hmm, ok thats pretty simple, the kind of stuff I was lookin for.
I still like the idea that I can use the master/slave prop setup as a state machine with my clocking method.
Its almost like you can control slave props without even telling them anything... except adjusting their clocks so they change their states.
I need to look into your simple suggestion and also my method.
Hello Debris
Leon
Hello Debris
