Looking for a homebrew Solid state relay circuit...
Does anyone have or know of a good homebrew circuit for a solid state relay.·
Needs to be DC input, and able to·switch up to 10 amps DC at the output.·
Thanks· DenO
Thanks· DenO
propmod_us and propmod_1x1 are now in stock. Only $30. PCB available for $5
Need to upload large images or movies for use in the forum. you can do so at uploader.propmodule.com for free.
Greg
And McTrivia...the opto with the darlington pair doesn't produce a low enough "on" resistance. To much heat would be generated at 10 amps of conduction. Does anyone know what components are used in making a solid state relay?
DenO
Leon
Amateur radio callsign: G1HSM
Suzuki SV1000S motorcycle
Leon...actually, a DC to DC 10amp solid state relay costs about $30 to $40 each, and I need 4 of them. To handle that many amps, the SSR's usually come in what they call the PUCK type with screw terminals. PUCK type, meaning Hockey Puck 'looking'. Never the less, thank you for your reply.
DenO
uk.rs-online.com/web/search/searchBrowseAction.html?method=getProduct&R=2448993
Leon
Ain't gadgetry a wonderful thing?
aka G. Herzog [noparse][[/noparse] 黃鶴 ] in Taiwan
Leon
see attached PDF....I have used these frequently in prop based designs .
These are used quite a lot in automotive light control modules.
··········· John
EDIT: in fact I am just assembling a few boards as I type . See attached images
'Necessity is the mother of invention'
'Those who can, do.Those who can’t, teach.'
'Convince a man against his will, he's of the same opinion still.'
Post Edited (QuattroRS4) : 6/25/2009 1:28:27 AM GMT
propmod_us and propmod_1x1 are in stock. Only $30. PCB available for $5
Want to make projects and have Gadget Gangster sell them for you? propmod-us_ps_sd and propmod-1x1 are now available for use in your Gadget Gangster Projects.
I know not every ones into switching 300amps (I play around with welding machines), But I can see all kinds of uses for a 30amp IGBT vers.
I often need to switch 120vAC with a 5volt 20ma or less output. I have a bunch of opto 22s 5v That are made to sw/ 120vAC with a 5vDC input, but the input current exceeds the output current of the STAMPs so I'd have to use a driver anyway.
___________$WMc%___
The Truth is out there············································ BoogerWoods, FL. USA
IGBTs are nice though. GREAT for high-freq applications. I've got some samples from ST Microelectronics that are good for 30A, 600V continuous. I'm thinking about making an inductive heater with them!
.. These were taken with a mobile phone (cell phone for those states side) no flash and bad lighting .. and merely as a reference to items mentioned..
Rgds,
John
