A/D, D/A, & analog switches @audio freq's - your recommendations?
CounterRotatingProps
Posting here in the sandbox because the MC could be either a Prop, SX or both.
Intention = generic and wide-ranging·audio experimentation and signal generation
Min sample speed: uncompressed CD audio, mono, c.a. the 44.1 kHz 'standard'
Max s.s: 128 kbps
Prefer 16 bit, 24 could be better.
I am·aware that the Prop. is fully capable of serious audio work, but I'd like to off-load the conversions.
So the·parameters·are the typical Functionality vs. Price vs. Pins consumption.
1] Straight pin-4-pin, MC to A/D - D/A = Pros: speed, price. Cons: gobbles up pins.
2] I2C or SPI interface --- though·I understand the protocols generally, I don't·know if these are too expensive or difficult to control.
3] Even using the SX as a virtual A/D - D/A device wouldn't be out of the question, but am really looking for chips.
Any recommendations would be very much appreciated.
thanks,
- Howard
Got Electrons?
Max s.s: 128 kbps
thanks,
- Howard
Got Electrons?
Leon
Amateur radio callsign: G1HSM
Suzuki SV1000S motorcycle
Post Edited (Leon) : 6/14/2009 10:28:44 PM GMT
Still would appreciate some suggestions for A/D & D/A stuff though as I'd like to 'roll my own' for a little practice again.
Forgot to mention what's in the title ... am also looking for analog switches that are low-noise (when switching on/off that is) and inexpensive - for building a digitally controlled audio patch bay.
cheers
- Howard
Got Electrons?
thanks
- H
"This device contains recyclable materials, which can be re-decomposed
and re-integrated into brand new marvels... We strongly encourage you
to contact the provided information and recycle yourself always. "
Leon
Actually, I guess I shouldn't be so amazed at how many DSP+MC combo's there are. (Off topic: maybe the PropII will have some DSP onboard?)
If you were wanting to build your own function generator (for example), what would you suggest. Yes, I know that's a really very broad specification... just the general drift...
thanks again
Cheers,
Howard
I've used an AVR with a software DDS as a function generator up to 200 kHz or so:
www.geocities.com/leon_heller/minidds.html
Leon
Leon
I'm thinking of doing the same at some point, more along the line of learning notes. But it's time consuming...
Posting your circuit board diagrams is helpful too. You "radio men" know a thing or two about RF - which certainly applies to the frequencies of controller and ancillary circuits these days. (E.g., the recent thread on capacitor placement.)
- H
