Triggering 10A Relays - Best Practices Requested
My applications needs to be able to trigger a 10A relay. My current solution is to use a Darlington transistor array to trigger a small 5v relay. . .which then triggers the 10A relay. This is to keep the current draw on my Stamp pins to a minimum. . .plus they can't trigger the 5v relay anyways, they don't produce enough current.
Is this approach the best way to do this? It seems a bit overly complex to me. Any best practice recommendations?
-Jeff
Post Edited (everest) : 6/18/2009 10:18:22 PM GMT
-Jeff
-Jeff
There's nothing like a new idea and a warm soldering iron.
····http://forums.parallax.com/showthread.php?p=816702
