How does the SX compare to the BS2? — Parallax Forums
electromanjelectromanj Posts: 270
edited 2009-06-19 00:11 in General Discussion
Hello. I have some basic questions about the sx chip. I have used the basic stamp 2. What are the basic differences and similarities between the bs2 and the SX? Is the sx programming similar? The projects I make usually include a serial LCD, and if px is high then do this, if px is low do that. Also I am just starting with RFID. Can you use this with the sx chip?
Thanks in advance for your help!
    edited 2009-06-17 23:13
    The biggest difference between the basic stamp and the SX chip is SX/B is an inline compilier. Meaning you should (not neccesarily HAVE to) make SEROUT, ect subroutines to save space on the sx chip. There is a bit of a learning curve (made easier with great help) compared to the stamp. Bottom line: the stamp is easier, with less "newbie" hassles and mistakes, but the SX is cheaper and LOTS faster. Think of it as midway between stamps and the propeller.
    IMHO. [noparse]:)[/noparse]
    Shawn Lowe
    When all else fails.....procrastinate!
  • electromanjelectromanj Posts: 270
    edited 2009-06-17 23:57
    Would it be safe to say that you can do more with the SX than the bs2, but the SX is a little more advanced as far as the programming? Is it a stand alone product or better as a slave for the stamp? My current projects are not that big and it would be nice to use $4 mp versus a $30 mp, I usually shuttle my stamps from project to project. It would be nice to build it and leave it there!
    Thanks for the help, I had seen the sx forums before but never paid attention. Took a closer look at the parallax store today and I am really curious!
  • CounterRotatingPropsCounterRotatingProps Posts: 1,132
    edited 2009-06-18 00:33
    yes and no. It depends on what you want to do. The SX is more 'low-level' in some ways, but with SX/B programming it's relatively easy to do. But as Shawn says, there is a learning curve. If you give it enough time, study the code samples, get a simple SX board, read the N&V articles, ask here, and just go for it, you'll be able to do a lot of things with it that are beyond the stamps.
    Again, yes and no. SX/B is pretty easy to use because the good guys here who wrote it did such a good job.· And it will help you learn SX assembler if you want to do that - but you don't necessarily have to code in asm.
    Like the Propeller, it's an amazing little chip. It can be stand alone, or work in concert with other MCs.· For example, you could use the SX as a controller for some kind of communications protocol, doing the dirty work of the sending and receiving of bits while the Stamp is the Brain, sending simple commands in a more human understandable format.
    Yes, it does get a little expensive to burn up a board with chips for each project - and it's a pain to have to take it all apart for the next thing, if you don't make it perminant. Here's what I like to do.· When I'm learning a new device, I get a demo board, or an "evaluation" board (if I can afford it) - AND I get a protoboard or two. That way, I can breadboard some tests and ideas, then make it semi-perminant on the proto board. Then my demo board is freed up for the next experiments. If it's really important, I'll make a real circuit board and stuff the chips on there for good.
    Electromanj, the people on this forum, like the rest of the Parallax forums, are very good and helpful people.
    Ask and you will receive!
    cheers,
    And welcome to the SX side of the Parallax Planet [noparse]:)[/noparse])
    - Howard in Florida
    "This device contains recyclable materials, which can be re-decomposed
    and re-integrated into brand new marvels... We strongly encourage you
    to contact the provided information and recycle yourself always. "
    edited 2009-06-18 01:31
    Note: I don't know how to properly quote other posts so purple italics are other posts for now. Thank you for your understanding.eyes.gif
    Shawn and CounterRotatingProps, Thanks for the replys!
    As far as the learning curve, that is great because I was looking to move on to a new MC to learn more. (Evan though I haven't scratched the surface with the bs2). Sometimes a new experiance helps me better understand a familiar environment; can't see the forrest for all the darn trees!
    I could not agree with you more! I am not at all aprehensive about learning a new format because of the EXCELLANT professionals at Parallax coupled with the EXCELLANT professionals that frequent these forums. I am a Parallax fan through and through.
    Are you able to use inputs and outputs like you do with the bs2? Are the HIGH pinx and the LOW pinx similair?
    I was planning to get the starter kit for the SX chip. I built myself a very nice protoboard for the bs2 with spring terminals for pin connections which helps out alot in the design. I am hoping the SX will replace the BS2 in my most basic designs so I can populate my home with my mad scientists thoughts!··freaked.gif Wierdo lighting, ECT....
    I second, third, and quaduple that motion!
    edited 2009-06-18 12:36
    I would suggest you download the SX-Key software (v. 3.2.92) and study the help files. It has a lot of demos and can answer most of your questions on the Inputs, Outputs, capabilities of the SX chips. And if you don't go down the SX road, you can just delete the files! [noparse]:)[/noparse]
    Also, at the top of the forum is a sticky for downloading v. 2.0 of SX/B compiler
    Shawn Lowe
    edited 2009-06-18 15:03
    Electromanj, to quote, just click the little cartoon bubble that has the " ! " in it at the top right of the post you want to quote. Or just do it the old-fasioned way like this:
    Yes, but the you have to invert it - this is well documented. Shawn's suggestion is good. There's also a great piece of software called the SXSIM, it's a sticky thread too, but here it is anyway:
    http://forums.parallax.com/forums/default.aspx?f=7&m=53539
    If nothing else, run this thing just to see what is possible with well-written software --- it's a great learning tool and helps with debugging. And you don't even need an SX to try it.
    When you put together your starter kit, make sure it has, or you get, either the SX-key or the SX-blitz. You need one of these to get the program into the SX. The SX-Key costs more because it has more features and supports debugging. The SX-blitz doesn't do debugging, but costs less - it's more for loading SX's in a production-like way. I'd just get the SX-Key and be done with it.
    You certainly can replace all of your stamp stuff with SXes, but you will have to translate all the code, and some of the logic. SX/B is Basic-like (Maybe that's what the "B" stands for??) so the transition won't be too bad.
    RE - house lighting: there are some sample programs for doing stage-light control and X-10 control. In particular, you might want to study the N&V articles on the subjects available from the Parallax main site. The author does a very good job at showing a workable schematic and code. He's also a helpful and regular contributor here on the forum. When we *really* get stuck, he'll jump in and help.
    My personal opinion is that the SX was made by Mad Scientists Just FOR Mad Scientists... freaked.gif
    lol.gif Igor, pass me the SX-Key !
  • ZootZoot Posts: 2,227
    edited 2009-06-18 17:28
    To a certain degree the Stamp and SX are apples and oranges. Given that you can use SX/B which contains many of the same commands as a Stamp, there are similarities in how you might set up your code, but that's about it.
    The two big *strengths* of the Stamp that you won't have on the SX are built-in EEPROM (i.e. read/write/store data in non-volatile memory) and the "compactness" the Stamp's interpreted language. In a sense, every command on the Stamp is really a kind of ready-to-go subroutine but without the subroutine taking up program space. On the SX, this is not the case. In other words, I would argue you can fit a lot more program into a Stamp.
    On the other side, the SX can do a lot the Stamp can't -- like true "background" interrupts so you can, for example, constantly send out servo pulses, or PWM, measure inputs, etc "in the background". Also you can do "real-time" counting -- so if you need to have an event occur every 10 seconds, or 2ms, or whatever, it's not hard. The Stamp will never do that. And of course, the SX has more I/O pins available (20 on the SX28 dip) than the 16 I/O pins on the Stamp. Additionally, with various brown-out settings, the SX can be operated with a broader range of voltage supplies. Lastly, the SX is *blazingly* fast.
  • Jason-WIJason-WI Posts: 35
    edited 2009-06-18 22:38
    If you are leaving stamps on completed progects you can use OEM components and save 1/2 the cost of a BS2. Just take a little more time to complete your project. Your will need a BS2 interper, EEPROM, and resonator at minimum.
    http://www.parallax.com/Store/Microcontrollers/BASICStampOEM/tabid/135/ProductID/12/List/1/Default.aspx?SortField=ProductName,ProductName
    He who dies with the most toys wins!
    edited 2009-06-18 23:10
    First of all I have to say this: The people on this forum are A+ number one!
    So much help.
    I am getting one theme here, and that is to download some resources to get familiar. Great advice as I learn more by trial and error, (mostly from error).
    What I think would help the most at this point is looking at some sample projects. I would like to look at some hardware schematics coulped with some software·program·to cross reference. It best for me to look at the schematic and look at the code to understand what the code is doing. Is anyone aware of some nuts and volts articles that have a project description from start to finish?
    I am sure there are some included with the literature that comes with the sx starter kit, but I would like to look at some sample projects before I dive into this to be sure I am heading down the right alley.
    Thanks to all!
    Post Edited (electromanj) : 6/18/2009 11:23:41 PM GMT
    edited 2009-06-18 23:40
    Jason I like the homemade bs2 and have used it.
    That is one way to go.
    I guess I'm looking for a way to keep the cost down for minor one off projects, and more importantly mass produced projects.( I have these ideas....)
    There are a number of start-to-finish SX projects in the Nuts/Volts columns, esp. vol. 8
    www.parallax.com/Resources/NutsVoltsColumns/tabid/272/Default.aspx
    Also the SX/B help file has a number of projects with schematics, code, etc.
