Pull-up or pull-down resistors for switch?
John Abshier
I vaguely remember reading about reason to pick one or the other.· Alas, I don't remember which it was or the reason.· The PE Kit uses pull downs.· The PPDB uses pull ups.
John Abshier
John Abshier
If your switch goes between input and vss use pull up
if your switch goes between input and vdd use pull down.
if your input goes through a switch to another input(matrix configuration) use pull ups for active low inputs and pull downs for active high inputs.
propmod_us and propmod_1x1 are now in stock. Only $30. PCB available for $5
Need to upload large images or movies for use in the forum. you can do so at uploader.propmodule.com for free.
