AC Power
Could you guys look this over and tell me if I'm missing anything. Some of the components may be incorrect, like the rectifier,·and the reg shld be 3.3v. What size caps are recommended·?
Does it need any transducers or tachometers?·
BH
BH
propmod_us and propmod_1x1 are now in stock. Only $30. PCB available for $5
Need to upload large images or movies for use in the forum. you can do so at uploader.propmodule.com for free.
Seems high since it will be a 3.3v regulator..lots to dissipate. Maybe just use the center tap and one of the others
as the input and have like 6v into the bridge and approx 9v to the regulator?
The smoothing cap is only 470uF and so would have a large ripple voltage at 1A this would therefore reduce the overall power disipated in the reg. This is the technique used in those cheap crappy wall warts, eventually the dips would reach a point where the dropout of the reg is reached. Heat and ripple current would wear out the cap and the available "current-before-ripple on output" would get lower and lower (The great advantage of wall warts is they fit into the hand and so a good throwing range can be got) so use a good quality one with a high ripple current rating, and 105 degrees C.
If the centre tap is left as is, and the connections to (4) of the rect is dissed and transfered to that CT, so that only the diodes from 1,2,3 are used then only·about 8 Volts will be available to the reg. This is too close to the dropout of the reg, about 7V. the only thing that could be done to help this would be a much larger smoothing cap, but that would rely on low impedance from the transformer and rectifier so that the replacement energy comes a high current pulses. It would have to be at least 10x larger in value, I think it was about 2200uF per Amp per volt ripple, at 50Hz.
As mentioned already a larger cap on the output side is needed. Keep the little one as well for the high freq (ESR)
I have just notice that you want 3,3 Volts so the headroom shouldn't be so much of a problem.
Post Edited (Toby Seckshund) : 6/11/2009 10:02:18 AM GMT
Leon
Amateur radio callsign: G1HSM
Suzuki SV1000S motorcycle
interesting, Leon, what's your rule of thumb for the cap voltage rating versus desired operating voltage?
These little short cuts are treasures!
thanks
- Howard
Got Electrons?
> you would have a shotgun go off in your circuit.
Ah, you do mean 'you *won't* have a shotgun go off ' - right?
- Howard
<<-- note the smoke [noparse]:)[/noparse])
Got Electrons?
Normally does nothing but in case of failure stops voltage from going to high.
Everything nowerdays is expected to be so small that it will fit into a matchbox, in the olden days the power supply was assesed and the doubled/tripled for long term reliability, even if it did take up half the room. And it would never be allowed to become any more than pleasently warm.
But then ... A laptop built to these maxims would be a tad heavy
Many years ago, I worked on 300KW HF TX, the 11KV 3 phase mains was full wave rectified, smoothed a bit (doesn't need much) and stuffed onto the anodes. Faults were brutal!! The fuses were nicked to make rolling pins. The power rooms, for these sets, were rooms.
No surface mount nonsence there, you needed spanners.
After reading through everything I have made a few changes. Some of the component #'s might be wrong bc I have no idea what some of the them mean. When building it I would get the correctly rated items (hopefully).
I am thinking about using p/n 030-7329-0·from Pulse Eng. as the transformer.·Is that what I shld use, or would something else be better?
I will also be adding a 3v reg after the 7805. What should·the cap config before and after that look like?
This will be powering a mcu, 3-5" LCD, keypad, and some small relays.
BH
Watch out for the backlight of the LCD it will probable be the biggest current consumer, next will be the relays, low volts=high current , budget for worst case ie everything on together
"next will be the relays, low volts=high current"
If I use a charge pump and higher voltage relays would that reduce the current draw?
BH
This could be a problem if 32 of them ended up closed at the same time.
There is nothing to say that the relays do not get powered pre regs, whatever the tfmr you choose will dictate the voltage of the relays. Relays thake a big pull to get them closed but less to keep them closed, so a 12 relay will take 3/4+ of that to close smartly. They certainly do not req reg volts. obviously use a transistor to drive them anyway and place a reversed diode across the winding to catch the back EMF ( huge reverse voltage spike when the magnetic field collapses ) a common 1A diode should be ok. ULN2803s are built for this
Charge pumps cannot create energy the extra volts come a the cost of higher current so you just loose by the inefficiency.
Style and grace : Nil point
Post Edited (Toby Seckshund) : 6/14/2009 7:46:23 PM GMT
That's a great idea.
BH
If You will not have problem use 2 rectifiers parallel.
One to regulated and one to unregulated power.
Eles if You use power to drive relays from traces before regulator all EMF from them come directly in reg.
For every stupid question there is at least one intelligent answer.
Don't guess - ask instead.
If you don't ask you won't know.
If your gonna construct something, make it·as simple as·possible yet as versatile as posible.
Sapieha
I have been thinking from the beginning that it looked very sparse.
Any ideas for Bridge Sizes - or are those 9mm singles in 4's more economical?
I just remembered a board I found. I always liked it for it's Rigid Simplicity. But this is pretty much the power supply I would want for the relay stage?
AC comes in the 2 tabs @ the front
BH
Post Edited (BADHABIT) : 6/15/2009 3:21:31 AM GMT
