Pin state of prop after prog halts
Playing with stepper motors I noticed that the motor current comes back on when the prog stops. I know that this is abnormal for a final system but is there some magic code that leaves the props outputs in a low state ? (apart from an endless loop escape)
Or should I adopt a negative logic for the motor drives
Style and grace : Nil point
Leon
Amateur radio callsign: G1HSM
Suzuki SV1000S motorcycle
On that note ...
When are we going to stop all this high faluting mumo-jumbo of which programming language is "the one true language" and build the automatic lawm mower with navgation sight and ears.
If it could be powered by empty bear cans ... BONUS !!
