PropellerLoader
Clock Loop
No matter how hard I try, the OBEX propeller loader will not let its self be put into a new cog.
I tried to add this to the top of the propellerloader.spin file.
What am I doing wrong?
I try to lauch it by using this:
loader.Start(PropRst, PropRx, PropTx, 1, loader#LoadRun, @PropBinary)
Post Edited (Clock Loop) : 6/12/2009 7:36:16 AM GMT
long cogon, cog ' cog status
long ProStack[noparse][[/noparse]1100] ' local stack
PUB Start (a, b, c, d, e, f) : okay
stop ' stop cog for this object if running
okay := cogon := (cog := cognew(Connect(a, b, c, d, e, f), @ProStack)) > 0
PUB stop
'' Unload timer object - frees a cog
if cogon~ ' if object running, mark stopped
cogstop(cog)
'the rest of the code is the same as propeller loader.
PUB Connect(PinRESn, PinP31, PinP30, Version, Command, CodePtr) : Error
Eccles : How do I open the door?
Bluebottle : You turn the knob on your side
Eccles : I haven't got a knob on my side!
Hmm, i don't know why I didn't think to try that..
Will try.
Yes it works if I just run
instead of
I have done this with a different object and it works fine, no idea why this doesn't like it.
Even if I run
cognew(Connect(a, b, c, d, e, f), @ProStack) It still won't run.
I checked the syntax in the prop manual and it shows the same thing.
Post Edited (Clock Loop) : 6/12/2009 8:42:57 AM GMT
Toys are microcontroled.
Robots are microcontroled.
I am microcontroled.
If it's not Parallax then don't even bother. :-)
Propeller SRAM TV driver winner: ==NOT COMPLEATED: 3 WEEKS UNTIL ENDING TIME==
If you need help getting it to work, I can help you. Its a really cool feature to have.
I just can't make it work in a new cog.
