Propellerized Boe-Bot
Hey Everyone,
I wrote Phil (PhiPi)·about this question and he suggested I post it here (so he can reply and everyone see it!).
I am going to mount a Propeller Proto Board on a Boe-Bot Chassis. I would like to eventually use the Boe-Bot encoder kit as well. Beside the usual 5v to 3.3v connection issue, would there be any other issues (beside the code of course)? Have any of you tried this? Thanks for any help or tips!
I will also have IR detectors,·a Ping))) and mounting bracket, a 2x16 Serial LCD. I am working on learning the Prop (mostly for Robotics) and I thought this might be a way to start on something practical.
Whit+
Post Edited (Whit) : 6/12/2009 3:02:27 PM GMT
Whit+
Remember that this is not a quadrature encoder. This implies that the encoder code needs to communicate with the motor control code, so it knows which direction the wheels are turning. The best option is to put the motor control and encoder code in the same cog.
Whit+
