tv_driver xtal problem
i am new to the propellor and this might be a stupid question, but
i have a propellor on a breadboard and i'm trying to do spin lesson 9 (using tv_terminal).
i'm having problems with the tv syncing to the ntsc signal. i don't have a 5 mhz xtal, but i tried to use a 20 mhz crystal as follows
_clkmode = xtal2 + pll4x
_xinfreq = 20_000_000
then i tried a using a 4.194304 mhz crystal using
_clkmode = xtal1 + pll16x
_xinfreq = 4_194_304
it works with this crystal, but the text is flickery, i thought that as long as the freq was high enough it wouldn't matter.
can anyone tell me what i'm doing wrong?
Just as a test, I rummaged through my junk box and found two crystals marked "4.9152MHz". One produced stable video, but no color, indicating a slightly off frequency. The other produced stable video and color, but there was fringing that may betray either a slightly off frequency or excessive PLL jitter.
My recommendation would just be to purchase the correct 5MHz crystal and be done with it.
