Stocking a lab = kits & 74xx vs 74LSxx vs 74LVCxx - your input requested.
Am stocking up a·my new lab space for doing general electronics experimenting - you know, your basic Mad Scientist stuff...
I've been looking at Jameco's·parts kits that come with drawer cabinets. They seem diverse and reasonable in price.
1. Do you all know of other/better places for similar kits (beside putting things together from Mouser or Digikey)?
2.·This may seem like an odd question, but I've been wondering if plain-old TTL stuff is still used much (e.g. 74xx) --- every time I go to do something on that level, I seem to need CMOS or 74LSx or maybe the voltage tolerant 74LSVx· series.· The reason I'm asking is that these kits aren't cheap, but I do want to well stock.
* So, if you had a choice between 74x ONLY or 74LSx· which would you prefer?
Or, if that's just a dumb dilema, would it be better to grab a bit of each and make up my own kit?
Please keep in mind this is *general* stuff...
* Do you really still use TTL only much?
thanks for your assistance!
- Howard
Got Electrons?
Post Edited (CounterRotatingProps) : 6/11/2009 12:16:42 AM GMT
- Howard
Got Electrons?
I guess the question is what do you want to build or learn, the newer low power 3 volts stuff is compatible with the prop chip I use that a lot as well. to better help you give everyone an idea of what you want to build
or do??
Having said that however I must ay that I use 74HCx almost exclusively now. This family operates from 2.0 - 6.0 volts and works well with the old 74x chips. I still service a fair bit of old equipment that was all 74x when new, and have been using 74HCx for several years to replace bad 74x chips without a single problem to date.
The nice thing about them is they also work with the 3.3V and 2.5V chips without needing a separate supply, and I have used them with a 1.8V chip by having a separate 2V supply for them and using 1K resistors on the signal lines.
Leon
Amateur radio callsign: G1HSM
Suzuki SV1000S motorcycle
--Steve
Propalyzer: Propeller PC Logic Analyzer
http://forums.parallax.com/showthread.php?p=788230
not doing much repair work any more (unless I've designed it wrong [noparse]:)[/noparse] --- it looks like I'll be grabbing an assortment then·of HC, HCT, LVC, and LS.
> Some HC/HCT parts get really slow at lower voltages.
Steve, as I'm uncertain how that might affect things, can you give a specific example, please?
cheers
- Howard
No matter how much you push the envelope, it'll still be stationery.
ACT are similar to HCT but give you high speed and are able to drive heavier loads.
Here's a link I came across with a guide to some logic families
www.maagtechnic.ch/public/pdf/ev/Logik_ICs/Complete_CMOS_Logic_Source_Selection_Guide.pdf
As to speed, well it's true that some of these parts run "slower" at lower voltages but normally that is never ever a problem.
My overall recommendation based upon interoperability and availability etc is the HCT series.
*Peter*
[noparse][[/noparse]EDIT: excellent overview - especially the way the tables cross reference --- also a great example of superior documentation, IMHO]
Having stuff stocked up is good for lazy, but spontaneous, types like me. [noparse]:)[/noparse]
- H
Got Electrons?
Post Edited (CounterRotatingProps) : 6/11/2009 12:14:25 AM GMT
One minor correction: the 74LVC parts can run at a 5V Vdd. They're rated up to 5.5V.
*Peter*
Phew!
TI LVC
Table 5: Recommended Operating Conditions
1) Truth Table guaranteed: 1.2V to 3.6V
2) VIN from 0.8V to 2V at VCC = 3.0V
Table 6: DC Specifications
Symbol Parameter Value Unit
VCC Supply Voltage (note 1) 1.65 to 3.6 V
VI Input Voltage 0 to 5.5 V
*Peter*
I don't know what part you're looking at, but the TI parts I use (e.g. 74LVC1G14) definitely spec a high-end operating voltage of 5.5V.
I'm thinking the OP is after standard stuff, even DIP.
*Peter*
Imagine how I feel about this - you guys have been using this stuff a while, whereas I've been out of the industry for some time, and knew I could count on you all to help me sort this out. It looks even more confusing now than before --- just kidding :-P Well, sort of:
Peter, Phil - I've been doing some pricing. The same chip and package, Jameco might offer for say $0.40, but Digikey has it for $1.20... I just assumed that Jameco is selling overruns, but with your recent exchange, I'm now wondering if the differential is really due to the quality of components (or LACK thereof??).
What's your insight here?
thanks,
-Howard
Got Electrons?
--Steve
