How wide is a PWM pulse?
People,
I have a question regarding PWM that i can't seem to find a suitable answer for. I looked it up on Wikipedia and am still no wiser...
If I had a signal that was operating at 1 second high, 1 second low, wouldn't that be PWM? (with a 50% duty cycle)? or how about 4 seconds high, 5 seconds low, or even longer.... wouldn't they all be examples of PWM?
So when someone is 'using PWM' to drive a servo for example - what is the 'accepted' timing of a complete pulse?
Thanks in advance
The future is in our hands.
Which way to the future?
Thanks in advance
Most servos use a 50 hz framerate. Every 20 milliseconds there is a pulse which varies from typically about 1.000 milliseconds to 2.000 milliseconds with 1.500 mS or 1.520 mS being the center. However servos are pretty tolerant, the pulse can come sooner or later than 20 mS and they still work - up to a point.
Rich H
Leon
Amateur radio callsign: G1HSM
Suzuki SV1000S motorcycle
Rich H
There are basically two components to a PWM signal you have a Base Period, and a ratio (or Duty Cycle) of time On verses time Off. The Base Period is usually fixed, but it can vary from Period to Period as long as the On/Off ratio is maintained. As for hobby servos, it is PWM but the Duty Cycle only varies from 5 to 10 percent of the Base Period with the Base Period being fixed at 20ms.
Beau Schwabe
IC Layout Engineer
Leon
Any particular reason why the 'carrier' frequency 50Hz? (I know it's not really a carrier, but I trust you get the idea)
Australian mains voltage is a 50Hz cycle - "lets make it that..", it's a round number for "twice the POV frequency of the human eye", "just pick some value at random" ???.
Not that I'm planning on doing any PWM stuff in the near future, but I would welcome the opportunity to expand my knowledge base...
There is a good discussion of this info (specifically for the Boe-Bot) in the Robotics with the Boe-Bot Book - You can download the pdf here for free - http://www.parallax.com/Portals/0/Downloads/docs/books/edu/Roboticsv2_2.pdf
It has lots of very useful infomation (as do all Parallax's Education Series books and all are free to download).
Whit+
