PWM module
Hi all!
I need PWM function (1-phase) in my controller with precious timing (quartz-stabilized as SX do), but SX28 have very small (8-bit) counter for that purpose. Have no idea how to implement exact timing ticks with code (maybe someone could share idea).
But the documentation mention two 16-bit PWM build-ins on SX42/52, and there are no any practice example with brief explanations nor for hardware timing mode neither for software timing mode . How to trigger output by hardware and method to trigger by code ?
The R1 и К2 can be accessed through mode registers, as I discovered, and RB.6 & RC.2 are outputs for T1 и Е2 respectively.
Regards.
Regards.
But it have precious timing requirement. So I need to build square-wave
CMOS generator that parameters are: n1: count of ticks for "1"
and n2: count of ticks for "0" logic, so it runs repetitiously,
nothing more else.
I have to use LCD display and 4x4 keyboard to input those two parameters
The value of them are located in range : 50-300 vs 150-3000 ticks
for logic "1" and "0" respectively. I almost wrote LCD+kb editor,
but timing of PWM is an actual problem for me. So I need help
me to preciously count values, stored in 2 doublebyte variables,
and toggle an output bit. That's all.
Previously I want to use SX28 due to DIP package, but for SX18-28 arch
isn't possible provide exact emulation of 16-bits timers, due to running
on single 8-bit RTCC register.
Regards.
Besides, I tried to build PWM on SX48, but it failed to simulate:
What is wrong with code ?
JonnyMac, as I wrote - 50-300 ticks for log. "1" ( with 75Mhz quartz) and 150-3000 ticks for logic "0".
HOW I CAN CONTACT SUPPORT TEAM ? NO RESPONSE AT ALL FOR ANY QUESTIONS.
Depending on your needs you can simulate PWN on any number of pins by using your own Interrupt routine to keep track of the counts. The nice thing about this route is that you can use any pin instead of the couple pins dedicated to the hardware timers.
The help file for SX/B has some information about the timers and there is a great deal more in the SX48 datasheet and another great source is Programming the SX Microcontroller by Gunther Daubach.
For the timer do you know the duty cycle and frequency you are tring to get? Not just ticks, but on for a number of ms and off for a number of ms?
Robert
to manual (I listed it in my prev. post), but it doesnt work.
If it not a problem, can you show a demo code or explain me
why my is not working.
Thanks a lot.
I have been following this thread, and while I can't help you do to my inexperience with the SX, I'm trying to learn.
What is a "tick"? Is it a clock cycle? And you want to run this SX chip at 75 Mhz? 50 clock cycles @ 75 Mhz is .66 microseconds or 1.5 Mhz. So, do you want a PWM routine that runs at 1.5 Mhz (Maximum)?
I am sorry if I am confusing this situation (and thread) more, but as I said, I am trying to learn.
Shawn Lowe
When all else fails.....procrastinate!
If you need 8 bits, then that is 256 levels, so you would want so setup the timers so that the on-time plus off-time always equal 256.
So for 50% PWM, the on-time and off-time would be 128.
The PWM rate will be the clock frequency / 256 (assuming no prescaler). So for 75 MHz that would be about 293 KHz (pretty snappy).
You must be careful when you are changing the on-time and off-time. Because if you set the value lower, and the timer is already past the new value...The output will not toggle until the timer counts the WHOLE way to 65535 and wraps around to the new value.
Bean.
There is a fine line between arrogance and confidence. Make sure you don't cross it...
I numerously explained what I need - precious, high-stability
digital generator of impulses with variable width.
Is there anyone who can help me and share working demo code that
show how to program PWM mode of 16-bit registers of SX48/52 chip ?
Documentation doesnt have any demo on 16-bit PWM,
just short explanation and registors description.
I tried to make code according but it doesnt work.
Bean, maybe you can forward my request to Ubicom developer team ?
Thanks.
Post Edited (Valio) : 6/10/2009 2:00:14 PM GMT
You've explained a PORTION of what you want to do at a high level but there are still questions that you need to answer in order for people to be more helpful. Even though you feel you have given all the required information there some pieces missing. I asked the question below but didn't see a response:
[noparse][[/noparse]quote]For the timer do you know the duty cycle and frequency you are tring to get? Not just ticks, but on for a number of ms and off for a number of ms?
There is a LOT of talented people on these forums and a lot are willing to help. When they ask for information that may not seem important there is often a reason for it even if it may not be immediately clear why that question was asked.
Some other details that would be useful to know:
- What language are you going to write your program? Is it going to all be done in assembly? In SX/B? Or in SX/B with some assembly code mixed in?
- Specifically what is the frequency range you are trying to obtain (lowest to highest). Not specified in ticks but in a frequency or cycles per second.
- What resolution do you need to achieve between the low and high range?
- Do you have a graph that shows the actual timing waveforms that you want?
I totally cant understand why you insist on ms amount, as far easy operate with clock cycle.
But let me mention again - I dont need fixed parameters, i wanna change them manually
with keyb+LCD as it would per need.
I've use the timers to drive PWM for controlling a motor and on another project used them to simulate pulses to drive a pair of servos. Having the details about the frequency range and resolution will help determine what clock speed you may want to run the chip and also what values to use for the pre-scaler.
Some example code fragments (for SX/B) that can be used in an SX48 (I was running at 20Mhz)
MotRht VAR RB.6 ' Right Motor speed/direction (PWM)
MotLft VAR RC.2 ' Left Motor speed/directiom (PWM)
dutyCycle VAR Word ' Should be 18Khz @ 20Mhz clock
dutyCycle = 49995 ' Overall cycle should be about 50 Hz
TIMER1 PRESCALE, 3
TIMER2 PRESCALE, 3
Then to set the timer and make it run use:
TIMER1 PWM, 2500, dutyCycle ' Turn motor on
TIMER1 PWM, 3800, dutyCycle '3750 = 150 (Servo not turning)
TIMER1 PWM, 5000, dutyCycle 'Turn motor on other direction
Depending upon your requirements you may have to reset the prescale value as well as the values of the timer itself to get longer or shorter cycles.
On another application I didn't want the Interrupts generated from Timer one and added some startup code to mask them off:
' The following code should disable Interrupts generated by TIMER1
ASM
BANK mtrStruct ' Make sure we can access timWrk
MOV W,#$07 ' Command to read T1CNTA
MOV M,W
MOV !RB,W
AND W,#$DA ' Clear bits 5, 2, and 0
MOV timWrk,W
MOV W,#$17 ' Command to write T1CNTA
MOV M,W
MOV W,timWrk
MOV !RB,W
BANK 0 ' Restore access to BANK 0
ENDASM
You could also do this for timer2 if needed
to turn off the timer you can use:
TIMER1 TIMER
You should probably try this all in SX/B first then move it all to assembly if you need to later. With SX/B it is very easy to experiment with the timers.
I checked your code - but unfortunately it doesnt work (at least at simulator), I cant catch any interrupts from T1/R1-R2 as far they was allowed. Meanwhile, in your code you are working with 16 bit registers, not 8 bit. I cant see where you load comparison registers R1 and R2 of T1 timer. I need that interrupt occurred when T1 will zeroed and reloaded again as manual says.
Maybe Bean is able to give me right answer ?
Thanks anyway.
When using SX/B the simple commands shown will set all the registers for you.· Once set it will start running and continue to run until you load a new value in it.· You don't need to reload the values after each cycle.· If so that would sort of defeat the whole purpose of a hardware timer to offload the work don't you think?· They are pretty much fire and forget.· No Interrupts required.· The SX/B help file explains the timer commands I used.
You set the prescale for and the duty cycle for the frequency you want.· The other value that I specified with the duty cycle in the example I provided sets the relationship to on time vs off time.· I have a small robot that I built with my son using the timers with some of the above code and I can assure you it does work.· I never tried it in a simulator but then I often don't bother with that and prefer to load the code on real hardware for testing.
Honestly there is much more than one right answer to just about any programming problem.· It is all in the way you look at it and the approach you take.· You should be able to use the timers or just roll your own via software in an ISR.· Either way there are hundreds of different ways to code the program to accomplish the task at hand.· What is right for one person may seem silly to another who takes a different approach.· Use whatever works for you and what you are most confortable with.
Good luck.
Did you see this thread?
http://forums.parallax.com/forums/default.aspx?f=7&m=356137
There is a program written by Jonnymac that might do what you want (after adjusting speed, ect.)
Shawn Lowe
I understand two things:
1) Simulator do not support neither PWM timers nor their generated interrupts. Its bad.
2) its very hard emulate work of 16-bit pair registers with single 8-bit timer of SX28.
PS: I do not yet received my SX-Key from abroad. I post a message to Parallax sales team
to help with sale order payment - but they ignore me - LOL )
Because I can use only simulator to prepare it for chip programming when it will be possible.
