Compiler Issue
Dear JonnyMac and Bean,
I'm unsing latest version of SX/B (2.00.24)
I used JohnnyMac code to: PUT array2, array1(0) TO array1(15)
I tried your code and it worked fine. BUT when I pluged the code into my program it did NOT work. ONLY the first two bytes were changed!!!
(in my code, since I'm using many subs, I had to move my SUB definitions·inside the interrupt area (based on Bean's recommendations) because the compiler complained when I had them before the interrupt code.)
I checked the ASM code of my program and I found that the compiler translated the PUT command differently (outside my program and inside it)·!!
What do you think?
the full code is below
Post Edited (SamTheMan) : 6/8/2009 10:52:36 AM GMT
What do you think?
FWIW, I recognize the names of all of those subs you're using because most of them come from programs I've written. You do not have too many, there is another problem.
1- I'm sorry if my big bold letters·was interpreted as SHOUTING
·· I was not trying to shout, I just wanted to make my point clear. (please accept my appology)
2-I removed the SUBs coding to make the text short and easy to read. ·and because these subs were mostly written by you, I thought there's no need to post the whole code of what you already know.
Anyway, here is the whole code:
Post Edited (SamTheMan) : 6/8/2009 10:51:25 AM GMT
Shawn Lowe
When all else fails.....procrastinate!
to answer your question check this:
http://forums.parallax.com/showthread.php?p=655596
So the answer is put your ISR code wherever you want (it's not a sub, btw, but an ISR) and GOTO following the INTERRUPT statement:
SamTheMan -- can you ATTACH (rather than paste) both your SX/B program AND the compiled output (.src)?
Shawn Lowe
and the ASM part is:
get_Requests:··················· ;Sub get_Requests
· CLR tmp······················· ;·tmp=0
· MOV FSR,#Temp················· ;put temp,que(0) to que(15)
· MOV __PARAM1,FSR·············
· BANK $00·····················
· MOV FSR,#QUE+0··············· 'I think the problem is here
· MOV __PARAM2,IND·············
· MOV FSR,__PARAM1·············
· MOV IND,__PARAM2·············
· INC FSR······················
· MOV FSR,#QUE+15·······'and here too·······
· BANK $00
· RETP·························· ;endsub
What I think IS a problem, however, is using edge triggered interrupts with the serial stuff; sure one might logically assume that the very short interrupt wouldn't bother the serial stuff but why take a change; I'd use ISR-driven serial and poll the inputs as required during the ISR.
why the compiler produce an ASM code·for PUT different (inside my program) than outside it?
THANK YOU !!!
The problem is a bug in the compiler.
In the "PUT temp, que(0) to que(15)" is that the word "to" must be in upper case to compile correctly.
I will fix this ASAP. In short the compiler evaluates the "to" as a comma. Changing "to" to "TO" will generate the correct code.
Bean.
There is a fine line between arrogance and confidence. Make sure you don't cross it...
This issue has been fixed.
Bean.
Dear JonnyMac, you owe me one (just kidding)
