Memory location confusion
Have come across a problem that am hoping someone can explain to me what is going wrong?!
When running this code:
and using Chips 'monitor' code to examine the memory, get a strange result.
In the spin code, 'flag' is 0x88 and Data[noparse][[/noparse]0] to 0, and in the asm code, Data[noparse][[/noparse]0] is re-assigned to value 0xAA.
But this is the memory dump when run -
So instead of Data[noparse][[/noparse]0] becoming 0xAA, the variable 'flag' does, and Data[noparse][[/noparse]0] remains unchanged.
Can someone tell me what is going wrong?
D
CON _clkmode = xtal1 + pll16x ' Crystal and PLL settings. _xinfreq = 5_000_000 ' 5 MHz crystal. OBJ mon : "Monitor" VAR byte flag byte Data[noparse][[/noparse]20] PUB start | item '' Starts 'Monitor' in another cog using pins 31 and 30 at 19200 baud. '' Use a terminal program on the host machine to communicate. mon.start(31, 30, 19200) flag := 136 repeat item from 0 to 20 Data[noparse][[/noparse]item] := item cognew(@entry, @Data) DAT org entry mov DataAddr,par ' the Data array address mov DataValu,#170 wrbyte DataValu,DataAddr halt jmp #halt DataAddr long 0 DataValu long 0
0220-6F 64 48 EC 23 32 00 00 AA 00 01 02 03 04 05 06 odH.#2..........
D
Quick fix, swap flag and data[noparse]/noparse.
I think you are spot on with the reason for this issue -·have worked around the problem.
Guess I need to modify my way of thinking, the prop is happiest when we work with its native longs, but my drummed in way of thinking is to·use the minimum amount of memory at all times.· Why use a long when a (word or) byte will do, why use a byte when a bit will do?· Of course can use·bytes as required, just need to consider that they need to remain long aligned.
Thanks for your help!
You've written 21 elements into a 20 element array.
