Before I build it
Any thoughts on this Memory Board? Designed from SPARE PARTS! *That explains why I have 9 2k sram and an 8k sram. Project also uses 2- 2x20 lcds, 9 leds (8 clocked off the data bus) a 3x4 keypad also on the data bus. I'm not looking for top speed data transfers but more of a large storage space.
Maxim is great for this, also Linear Technology. I just got 5 different pairs of IC's. It took 7 days, and it was free(at least for me - the postage on the envelopes says 4.95
BH
Post Edited (BADHABIT) : 6/6/2009 7:59:53 PM GMT
Ok maybe I should give a little more in depth information about the project here.... The plan is to hook it up to my guitar, effects processors, and computer / keyboard.... maybe even my sampler. I have several pieces and tons of ideas. The main part that is built and tested *although it will be receiving major upgrades* is the router. 2 guitar pickups into buffers... a long cable run into the main switching unit. Then off to the respective effects processors... The pickup switch is also sent over the long cable run and hooked up to pins. Also the 8 bit data line and clock for the selector. I am currently using a bs2 for this but plan on working on the proprpm.
The next module will be the Dynamics module. I have several ideas based around a VCA in an Alesis Microlimiter. Using a 0-5v control signal introduced directly to the vca. Any thoughts comments or suggestions?
Have you checked out www.openstomp.com. It is a guitar effects processor built on the propeller. It has 1.5MB of sram on board. He even published the schematic. Check it out!
Doug
