Prop Controlling a relay
I was looking at this relay:
http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail&name=PB389-ND
Data Sheet: http://relays.tycoelectronics.com/datasheets/d2n.pdf
I attached a screen shot of the info.
Can I drive this directly from the prop? it says the coil current is only 4.16mA.
Rick
Rick
My Prop Info&Apps: ·http://www.rayslogic.com/propeller/propeller.htm
I thought maybe this was a small enough one that could be used directly.
Its funny that I need the prop to drive a transistor...to drive a relay...to drive my actual load [noparse]:)[/noparse]
But I guess thats how it goes.
Btw in searching for the ULN2803 I came across this arcticle thats all about this sort of thing...and what do you know..its hosted by parallax: http://www.parallax.com/dl/docs/cols/nv/vol1/col/nv6.pdf
Rick
http://forums.parallax.com/showthread.php?p=687346
I thought the fact the relay you referenced having a +24VDC coil is the funny part. The low current of a few milliamps is the giveaway. The 2.4VDC that is mentioned in "one" of the columns refers to the absolute minimum voltage you can expect the relay to stay in after it has been energized at a higher voltage (this spec is for designers just to make sure it turns off).
Anyway, the Prop is a processor and not a power switch, there is no way you can drive a +24V relay directly from the Prop or any other low-voltage logic for that matter.
*Peter*
Toys are microcontroled.
Robots are microcontroled.
I am microcontrolled.
Not unless you want to fork out for a new prop chip.
Use a transistor or ULN2003 as was suggested be fore the drive the relay. If you use a transistor don't forget the back EMF diode.
There are many examples posted on this board.
Cheers
Adaequatio Rei Et Intellectus
Which is better for use with the prop the ULN2003 or the ULN2803?
If You ned "SOURCE DRIVERS" ity is UDN2981A thru UDN2984A
For every stupid question there is at least one intelligent answer.
Don't guess - ask instead.
If you don't ask you won't know.
If your gonna construct something, make it·as simple as·possible yet as versatile as posible.
Sapieha
