Another pair of eyes needed please
So i'm finished designing the circuit for my beacon, and i thought i would try and build my first real object (version one). Everything seems to work fine, and i did not have this problem about an hour ago, but for some reason i do now. The problem being the Suspend Signal button (ONOFF_PIN in the code). When the user presses the button it should stop the cog, then, when the user pushes the button again, it should start back up (running GenerateSignal in a new cog). The problem i'm having is that when the object runs, the first time the user presses the button, the cog stops. Just like it is suppose to. But when the user presses the button again (2nd time) the cog does not start up, nothing happens. At this point the LEDs that display the Beacon ID are still on (and they should never go out actually). When the user hits the button for a 3rd time, for some reason the Beacon Id leds all go out, meaning the repeat loop inside the Start method has either hung up or exited all together. But the funny thing is, a new cog starts with GenerateSignal.
I've been running through this code line by line for hours now and can't seem to find the problem. Below i have attached the object file (cause it is a little too large to include), and i here is the demo code that i used to run the object. Any help would be appretiated, and remember this is my first REAL object that i've created. I love critisizm but just remember that i'm trying my best.
-Mike
······ I'll try everything once [noparse]:)[/noparse]
CON _clkmode = xtal1 + pll16x _xinfreq = 5_000_000 OBJ beacon : "38kHzBeacon" PUB main beacon.Start(15,16,21,0,1)
-Mike
In the stop function you set it to 1 but never clear it again. As the OUTA of all COGs are ORed, it will stay 1 after the first stop.
Usually I would give the advice not to use one PIN in several COGs unless you have a good reason for that. But I guess your good reason is that the PIN should be high if there is no frequency output.
Another thing:
PRI CoordinateDisplay ShowBeaconID 'Display the Beacon ID in the indicator LEDs if myState == on 'If signal is being generated, turn on indicator LED outa[noparse][[/noparse]IND_PIN]~~ else [s][color=red]myState == off[/color][/s] outa[noparse][[/noparse]IND_PIN]~remove that or use elseif - which is not needed here and only adds execution time / memory usage.
if ina[noparse][[/noparse]ONOFF_PIN] 'If Signal Suspend button is pressed repeat while ina[noparse][[/noparse]ONOFF_PIN] 'Wait until the button is released ChangeState 'Change the state.Oh ... I see that kwinn already posted a comment on that. The repeat while comes short time after the if, so there is a chance that you find a low level from bouncing and you would immediately change the state.
Maybe adding some waitcnt would be a good idea as well. Just for a few ms.
By the way ... using OUTA[noparse][[/noparse]C_PIN] in the first COG would be enough to stop and start frequency generation. Simply let the COG run. Only drawback is that your signal will start with any kind of low-time for the first cycle.
Post Edited (MagIO2) : 6/4/2009 6:34:12 AM GMT
As far as letting the cog run, I have been thinking thats what i would do. But that does not change the fact that the code should produce another cog. Thats what gets to me, I really want to know why this is not working properly. But this could just be simply that the button is bouncing it's state cause instant ChangeStates and the rest is not catching up. I'll fix that first, then we will see what we've got.
Thank for the input.
-Mike
-Mike
Here is the finished product of 38kHzBeacon.spin that i wrote.
Thank you everyone for helping me put it together.
-Mike
if ina[noparse][[/noparse][color=red]CYCL_PIN[/color]] AND (! myState) 'If the cycle button is pressed an signal generation is suspended waitcnt(clkfreq/3 + cnt) 'Debounce the button repeat while ina[noparse][[/noparse][color=red]ONOFF_PIN[/color]] 'Wait until the button is releasedSo is that realy what you want?
Where did you get the SquareWave object from - can't find it? So this is currently just a guess: Isn't·SquareWave using the counters to produce to squarewave? If so, how can you call it 4 times? My expectation would be that it only drives one pin in your case.
As far as I can see you don't use BP2,BP3 and BP4, you only use BP5..BP1, so why waste the bytes?
-Mike
-Mike
I tried to the following, this might make more sense seeing it.
But the ".." is not allowed aparently in normal arrays. Only the special registers right?
-Mike
To set a bit to 1 'or' a byte that has all zeros except the bit you want to set to 1.
You can do this to set each bit.
Value := %1111000
There is almost certainly a better way, I'm sure someone will pipe up.
Rich H
Your SIGNAL is a variable of a certain size. In case of long it has 32 bits, in case of word it has 16 bits, in case of byte it has 8 bits.
If you want to initialize the SIGNAL you simply give a bit-pattern:
SIGNAL := %00001111
Please note, the bits on the left side are the Most Significant Bits (MSB). The bit following % is bit 7. This is very essential to know, because when you assign the SIGNAL to OUTA it can behave differently:
OUTA[noparse][[/noparse]3..0]:=SIGNAL in this case will set pins 0 to 3 to 1 -> easy to understand: bits 4 to 7 of the SIGNAL are not needed
OUTA[noparse][[/noparse]7..0]:=SIGNAL will set pins 0 to 3 to 1, pins 4 to 7 to 0 -> easy to unerstand: the OUTA range has the same size and order as the SIGNAL variable
OUTA[noparse][[/noparse]0..7]:=SIGNAL will set pins 0 to 3·to 0, pins 4 to·7 to 1 -> OUTA range has the same size, but different order than the SIGNAL
OUTA[noparse][[/noparse]7..4]:=SIGNAL will set pins 4 to 7 to 1·-> because in this case bit0 of SIGNAL will be copied to bit4 of OUTA
If you now want to modify single bits you need·bit operations. The OR (bitwise or operator is '|') will set a bit and the NOT·AND (bitwise not = '!',·bitwise and = '&') will clear a bit. With the |< operator you can generate a number where exactly one bit is set at the place specified after the operator.
|<1 will generate bit pattern %00000010 (as the bit number starts from 0)
SIGNAL := %00001111
SIGNAL := SIGNAL | |<1····· -> result: %00001111 as bit number 1 was already set
SIGNAL := SIGNAL | |<5····· -> result: %00101111
SIGNAL := SIGNAL & ! |<1·· ·-> result: %00101101
SIGNAL := SIGNAL & ! |<4····-> result: %00101101 as bit number 4 was already cleared
Did this answer your question?
Post Edited (MagIO2) : 6/5/2009 8:51:07 AM GMT
I have a variable SIGNAL that needs to be the combined value of data. So, what i need is
Rightmost bit needs to be data
Shift one bit left, needs to be data[noparse][[/noparse] 4 ]
MSB, left most bit, needs to be bit[noparse][[/noparse] 0 ]
When i monitor for the signal, i decode the value, either 0 or 1, and set it in a variable respective to it's position. So the first data bit i recieve goes in data[noparse][[/noparse] 0 ] then data... and then data. The problem i'm having is that i can only process one bit value at a time when monitoring, but in the end i need the bit pattern in a single variable.
I tried, like i said, this:
And the ".." is not allowed because it is not a register. But i do not know how to get the bit pattern stored in the array, in to one single variable.
I think i might just have to use a formula. I.E. the MSB in a 5bit variable is x16, the next is x8, the next is x4 the next is x2 and the final is x1. So i could use a formula like this.
That should give me a bit pattern stored in one variable.
-Mike
But more to come on this. I've made a drawing of what i will build the beacon in to. Using plexiglas to build a small cube (for the inards), and a smaller octagon on top. 4 sides of the octogon will contain 4 IR LEDs for multi-direction signal. Holes will be drilled in the remaining sides for future use of detectors. The next version will be able to talk back [noparse]:)[/noparse]
-Mike
-Mike
you could use
A multiplication is slower than a shift.
But why do you store the bits in an array and not directly in SIGNAL? Instead of
data[noparse][[/noparse] currentBit ]:=whatever you monitor
you can say
if whateveryoumonitor
· SIGNAL |= |<currentBit
Of course you have to set SIGNAL to 0 if you start reading from bit 0 again.
This is such a·perfect explanation with great examples, I vote for inclusion in the Propeller Tips and Traps.
OK Phil?
Jim
And your explanation IS a perfect example. I agree with hover1. Good on ya for those examples.
-Mike
