Problem with SXSim
Valio
Can somebody plz explain me why SXSim doesnt
correctly initialyze constant's.
I took some code from included samples:
The 0x and 1x row of reg file in simulator have
random garbage data instead initialized "1"
as it seen from code above.
So why study example doesnt work correctly ?
Thanks a lot.
Post Edited (Valio) : 6/4/2009 10:05:23 PM GMT
ORG $8
temp DS 1 ;temporary workspace
ORG $10
acc0 DS 1 ;pwm accumulators
acc1 DS 1
acc2 DS 1
acc3 DS 1
acc4 DS 1
acc5 DS 1
acc6 DS 1
acc7 DS 1
duty0 DS 1 ;pwm duty cycles
duty1 DS 1
duty2 DS 1
duty3 DS 1
duty4 DS 1
duty5 DS 1
duty6 DS 1
Thanks a lot.
You're not initializing those variables, just setting aside space. The "1" means "make this variable take up one byte of memory", not fill this variable with the number 1.
PeterM
I thought vars could be initialized this way, not just reserving space
I took PWM.src example from "SX Assembly" directory of installation.
If it's so, means this code doesnt works, as far vars contain garbage?
Could you take a look plz.
All above means it not possible have pre-initialized variables and
they should be set by itself fro constant. How can I make org directive
refer to program space ?
Alex
Post Edited (Valio) : 6/5/2009 5:31:24 AM GMT
You're a bit too quick to say the program "doesn't work" -- it does; what it doesn't do is initialize the PWM settings. Random values in the duty* variables will be output to the port; the values in the acc* registers will be overwritten every time the interrupt runs so they're it doesn't matter that they're not initialized. If you look at the code you'll find this comment:
This is an invitation to set one or more of the duty* variables before running the loop (at Main). You can use mov for a non-zero value of clr if you want to set a duty cycle register to zero.
Post Edited (Zoot) : 6/6/2009 6:05:56 PM GMT
