Hall sensor
I would like to connect a hall sensor to a Bs2sx microcontroller.
I have a hall sensor with two wires (Obviously, + and ground).
Could you help me on how (Circuit) I could connect this element ?
Thank you in advance,
Dave
Dave Andreae
Parallax Tech Support·
So, There is no need of a circuit for connecting this hall sensor to BS2SX.
Thanks.
Dave
Dave Andreae
if a relevant circuit is necessary in order to connect it to Bs2sx microcontroller. The desired scope of this switch is to detect relevant
magnetic field in order to, forthwith upon detecting, activate accordingly a port of the micro controller
i.e. IF(IN10=1) THEN
OUT11=1 ELSE
OUT11=0
ENDIF
,where port10 : Magnetic switch
port11 : Alarm
