Trouble understanding the "count" function.
I have a bs2. I have a program that blinks a led on and off. I need the led to blink 10 times and then end the program. Any ideas on how to do this? Do I use a count command? If so how do I do that?
The COUNT command is used to count INCOMING pulses.
I would use a FOR...NEXT loop
FOR temp = 1 TO 10
' Your blink code
NEXT
Of course you will have to declare the variable "temp".
Bean.
There is a fine line between arrogance and confidence. Make sure you don't cross it...
For your particular needs, look at the FOR / NEXT statement chapters in the Stamp Basic Syntax and Reference Manual. You can download this from Parallax if you don't have it already. There are also examples in the "What's a Microcontroller?" tutorial also downloadable from Parallax.
Go to the main Parallax webpage and click on the Resources tab, then click on Downloads, then Stamps in Class Downloads.
counter VAR Byte ' counter variable to hold what count number you are on led PIN 15 ' one leg of LED connected to this pin with proper resistance in series FOR counter = 1 TO 10 ' counter starts off as 1 HIGH led ' whatever pin you wish to change state PAUSE 500 ' half second pause LOW led ' same pin you wish to change state PAUSE 500 ' half second pause NEXT ' adds one to counter and returns to FOR again if counter < 10 ' when counter = 10 then the loop breaks and goes to next piece of code or just put END to stop the programTo change how any times it blinks just change the 10 to whatever number of blinks you want. To change duration, change the pause duration. Hope this helps.
will sound.I have the program and the program for tone working but I cannot get it to step to the next relay
any ideas? I want to use the same sound for each relay. How do i get it to second relay after sound.
(next,return)?
relay 1
sound
relay 2
sound
relay 3
sound
relay 4
GOSUB relay1 'contains Relay ON, Time, Relay OFF code, ends with RETURN
GOSUB sound 'contains code for tone including nested sub, end with RETURN
PAUSE xxx 'optional pause before relay2
GOSUB relay2
GOSUB sound
PAUSE
GOSUB relay3 .....
a more efficient way would be to have one generic Relay subroutine to which you would pass parameters indicating which output you wish to control and how much time.
after 255 so it never reaches 900ms.
counter VAR Byte 'holds the counter FOR counter = 1 TO 15 'cycles 15 times PAUSE 60000 '60,000 milliseconds = 60 seconds = 1 minute NEXT 'when counter = 15, loop breaks 'total duration of time will be 900,000 milliseconds which is 15 minutesThe pause function is limited but I think this for... next loop can just cycle what the pause function is capable of and achieve your desired pause. Hope this helps!
