I need more programming space!
Hello,
I desperately need more programming space for my project. . .I'm currently using a BS2. . .is a BS2e pretty much just like a BS2 but with more programming space? I can't really tell from the descriptions. Thanks!
-Jeff
-Jeff
If you don't want to change modules I suggest that you post your code (as an attachment) and get feedback on how to make it more efficient.
Be aware, if you go this route - that there are some timing and pulsing issues as the sx runs a 50mHz clock, while the regular old BS2 runs a 20mHz clock.·
Hope this helps!
Dave X
The Stamps other than the BS1 and BS2 come with what's called Scratchpad RAM. This is extra memory, but it can't be used as variables. The GET and PUT statements and one "formatter" (STR) are used to access it. The Manual has chapters on GET / PUT / SERIN you should read.
My code is ridiculously inefficient I'm sure. . .I'd be embarrassed to post it until I've taken a shot at optimizing it myself. I'll post it in a few days and see if anyone has comments to help me continue to learn. Thanks!
-Jeff
Does the BS2e require a different compiler? How do you push in two different pieces of code?
-Jeff
Last question. . .will the new stamp module drop into my BoE?
-Jeff
Tracy Allen
www.emesystems.com
