Prop Video Player (?)
I'm toying with a video player for TV... (based on the BMP viewer I posted last week).
Don't know if it will work yet (not sure if SD card will work fast enough), but here's a sample of what it would look like:
My Prop Info&Apps: ·http://www.rayslogic.com/propeller/propeller.htm
Intended? Or is it media player?
OBC
New to the Propeller?
SD might give you about 15(20tops)fps at that res
are you adding an audio stream to it too?
I'm hoping for at least 15 fps. Not really worth doing if any less... I may just do it and hope somebody will assemblify the SD card reading to make it faster...
Audio would be the next step, of course...
· Home of the MultiBladeProps: TriBladeProp, SixBladeProp, website (Multiple propeller pcbs)
· Emulators: Micros eg Altair, and Terminals eg VT100 (Index)
You might want to look up "fsrw and friends" in the obex which has several examples of much simpler SPI SD card access, including one written in PASM; I would be a lot more confident trying to jack up the clock rate without all the extra stuff going on for IIC access that sdspifemto has.
I2C is 400Khz (well sometimes up to 1MHz is possible)
SPI is much faster, personally I run it at 4Mbps and faster is possible with counter tricks.
Largos - a nano operating system for the Propeller
www.mikronauts.com - a new blog about microcontrollers
Perhaps you could adapt Beau's SPI code. Please post anything that runs the SD faster as I think there are lots of us that would like fast code for this.
