Final decision!
Which one is better ALL IN ALL:· the SX Blitz or the SX Key?
(All in all means price, ease of use, all that stuff.· Just wanted to clarify that for those of you who don't understand.)
Thanks.
Quit buying all those fixed voltage regulators, and·get an Adjustable Power Supply·for your projects!· Includes an LED testing terminal!
Thanks.
The debugging features of the SX Key are nice. For someone whose time is expensive, whether in money terms or in terms of life goals, the $20 difference is a "no brainer".
If you don't have the $20 readily available or it means the difference between getting one SX Protoboard or two, getting an SX Blitz and $20 worth of other stuff may be a "no brainer" and you'll willingly put up with debugging in a bit more difficult fashion. You'll still get the job done.
Shawn Lowe
When all else fails.....procrastinate!
The adjustable clock and debugging features of the SX-Key are too important.
If you just want to burn chips....Then the Blitz is okay.
Bean.
There is a fine line between arrogance and confidence. Make sure you don't cross it...
The first time you write code that won't function the way you think it will, and have to single step it to figure it out...· Then·you KNOW why you bought the key.
-Dan
"A saint-like quantity of patience is a help, if this is unavailable, a salty vocabulary works nearly as well." - A. S. Weaver
SX key
The DeBug window is worth its weight in GOLD.
_______$WMc%_____
The Truth is out there············································ BoogerWoods, FL. USA
Thanks.
Thanks.
That is correct. When you use any of the BASIC Stamp interpreter chips you will also need an external EEPROM chip since that is where you program is stored instead of inside the SX chip itself. That is the difference. The interpreter chip will allow you to use a serial connection for programming and it can transfer the program to the external EEPROM chip which then contains the tokenized BASIC code. If you get a plain SX processor you need a special programmer to program the chip itself.
The chips that are pre-programmed are very easy to use with tons of examples online. They do cost more, require the external EEPROM chip, and are slower than the raw SX chips.
The SX chips themselves cost less (since you don't pay for the BASIC Stamp interpreter) and can perform much faster. You can also gain access to other features of the chip (interrupts, timers, etc) that you can't use with one programmed with the BASIC Stamp Interpreter. With SX/B you can still program in a BASIC like code but can do a lot more with these chips. It all depends on what you want to do with them. That will determine which chip to go with.
For debugging the SX-Key is something that is very useful. Once you get past that however you may not need the extra functionality and the Blitz is fine for just programming the chips. Either programming tool is a one time cost since they can be used over and over to program any number of chips.
Robert
Well, I am going to do all my schoolwork so I can build my penguin and think about the next·Parallax product·I will blow my money on.
