Newbie Questions
I just ran across the Propeller chip 2 days ago, I have been using the AVR controllers mostly but the Propeller sure looks like it might be fun.
The idea of no interrupts is a bit scary though! I'm so used to interrupt programming.
I am about to start a new project and was going to use the ATmega644p but since this part and the Propeller are exactly the same price I'm considering
using the Prop. I program the AVRs in C and asm. I see that there is a C for the prop but not a free one like the gcc toolchain for the AVR and ARM.
From what I have read the Propeller seems to require an external 32kb eeprom??? I wonder why they did not put 32kb of flash or eeprom right on the chip???
The external eeprom seems like a poor choice...but maybe there is a reason that makes sense???
I'm used to storing log data in the AVR flash and eeprom regions so that it is available the next time the controller powers up. Can I easily store data bytes in
the external eeprom required for the Propeller so that it is not lost between runs??? And is it easy to use a larger eeprom both to load the 32kb start-up code
and a lot of logged data? Also, is it possible to modify the Propellers program code at runtime? I'm talking about writing a custom bootloader here...so that I can reprogram
the Propeller using serial IO or whatever.
The one thing that really makes me crave the Propeller is its ability to output video to a vga monitor
This is so appealing that I would be willing to combine an AVR
and a prop in the same project just so I could pull data from the AVR and display it with the prop....it would add little to the project cost. If I dedicated all but one
Propeller core to vga video what is the best resolution I could expect to output ? I'd like to output 1440x700 or even 1680x1050 ... is that possible?
The lack of built in features is a little troubling since I am not a hardware guru at all..are there plenty of examples showing how to do simple things like
ADC, serial IO..etc?
Holly...
This is so appealing that I would be willing to combine an AVRand a prop in the same project just so I could pull data from the AVR and display it with the prop....it would add little to the project cost. If I dedicated all but one
Holly...
You can store stuff in external memory, but you need a bigger chip. See the Object Exchange on the Parallax web site for useful functions
Leon
Amateur radio callsign: G1HSM
Suzuki SV1000S motorcycle
Output to VGA is the reason I picked the Prop too!
I think I've seen 1600x1200 using 4 cogs.· Check the "Object Exchange" for the driver.
Combining the AVR with the Prop sounds like a great idea!
There may be a way to store the Prop code on the AVR so as to avoid the need for an external EEPROM...
My Prop Info&Apps: ·http://www.rayslogic.com/propeller/propeller.htm
There are text display drivers for a 1600 x 1200 pixel display, but there's not much left available in the Propeller to make use of it. Because of the data rate needed, the driver uses 7 out of 8 cogs (6 if you leave out the cursor) and most of the RAM is used for the display buffer. High resolution graphics (more than 512 x 384) is not doable because of the memory requirements.
There are plenty of examples (and ready-to-use code) for all kinds of I/O. Have a look through the Propeller Object Exchange (obex.parallax.com/). The Propeller was designed specifically to have all I/O done in software. Its flexibility that way is a feature.
One cog, for example, can provide up to 4 full-duplex serial ports with aggregate speed of 400-500KBps. A nice 80 x 40 VGA text display would use 2 cogs. A PS/2 keyboard handler takes a cog and there's one I/O driver that combines a PS/2 keyboard and PS/2 mouse driver in one cog. You can have two ADCs using one cog or one ADC and one DAC. Full IEEE floating point at a very reasonable speed takes two cogs. There's even a very nice vocal tract synthesizer that can sort-of sing 4 parts in stereo with spatial synthesis and the voices separated around the stereo soundspace.
if you need an spi-interface dedicate a cog to it (sourcecode free available in the obex)
and never care about will the interrupttimewindow be long enough as the routine runs
in its own cog compelety independendly the only limit is buffer-ram
if you need an I2S-interface decicate a cog to it (sourcecode free available in the obex)
if you need PWM just use the onboard counters (sourcecode free available in the obex)
if you need two counters use the two counters of one cog (sourcecode free available in the obex)
(counting independent of what the cog is doing)
selfmodifyng code can modify itself a billion times as your whole program
runs in RAM
if you want to store data on an SD-card up to 2 GB use the sd-card routines found (sourcecode free available in the obex)
look through the obex there are a lot of sourcecode-objects for a lot of different kind of sensors
even GPS-data parsing
best regards
Stefan
@Raymon Yes, I see no reason why I cannot mix a Propeller and an AVR on one board
@Mike Green Thanks for the help, I see you wrote several of the objects in the library.
I think we may have some of those Atmel eeprom parts you mentioned. I guess I could
piggy back one on top of the Propeller to cut down board clutter..it would be almost the
same as if it were integrated into the Propeller
@StefanL38 Yes, looks like I won't have to re-invent the wheel after all. How much circuitry
needs to be added to interface an sd card? I have a bunch of class two 256mb parts. Be cool if
I could pretty much just hot glue one to the board and solder leads to the contacts
Another question: I have lots of 20mhz crystals on hand, will they work fine in place of the 5mhz units that seem common to Propeller
projects? And will they be able to be multiplied by 4 for an 80mhz internal clock?
Leon
The data sheet actually states that an 8 MHz crystal is the maximum with the PLL. I prefer to stick to device specifications, but I'm fussy about that sort of thing.
Leon
Post Edited (Leon) : 5/28/2009 7:48:48 PM GMT
