Using spin to send data on a 38kHz carrier
I'm taking advice, in that i will be using a microcontroller to control an IR·beacon, instead of·just a 555·timer.·That way i can transmit actual data signals rather than just 38kHz that could be anything. I can create the 38kHz carrier but have not had good luck finding any information on sending signals and recieving signals through IR. I can manually create pause in between pulses, but I still won't be able to send high and low bits in between pauses.
Does anyone know where i can find the information i need?
-Mike
······ I'll try everything once [noparse]:)[/noparse]
-Mike
Leon
Amateur radio callsign: G1HSM
Suzuki SV1000S motorcycle
Say Beacon 1 ID = REST.0.0.0.1.REST
Beacon 2 ID = REST.0.0.1.1.REST
Beacon 3 ID = REST.0.0.1.0.REST.... and so on.
Check out the Square Wave PE Kit Lab:
http://forums.parallax.com/forums/default.aspx?f=25&m=343747
They have an example of a sony remote control signal half way down the page.
Hope this helps,
Doug
I'm sure SPIN is fast enough, as your bit rate will need to be much slower than 38KHz. This assumes you use a timer to generate the carrier.
Ken
I really liked the Square Wave object introduced in the Lab. The quality of the Labs is exceptional.
Andy, are you listening? You need to ask for a raise
JMH
Now Phil, i'm interested in what you were saying. From going through this Lab in the link above, it seems that it works almost like what you are talking about, except it is not using the FullDuplexSerial obj. Bascially i would have to manually configure high time, low time (ie .6ms = 0, 1.2ms = 1 for SONY configuration that is) possibly just using constants as reference. That way i could have a bin number, say 0101, then using my constants a method would either send out a 0 (.6ms) or a 1 (1.2ms) respectively. Now, the FullDuplexSerial i thought was used directly to send information to the serial terminal on a pc. Your saying that i can actually switch that to output to a pin, and in this case the same pin as the output to the IRED, right? And, being that I am holding that pin high, when the serial data gets ORed together with the frequency data, i'm left with the serial representation inside the carrier frequency? Is that right?
-Mike
Post Edited (JonnyMac) : 5/26/2009 6:24:23 PM GMT
Post Edited (morris4019) : 5/26/2009 9:07:40 PM GMT
Your LED is backwards.
_____________
morris4019,
Your A15 pin should be set as an output always. Otherwise the counter will not output to it, nor will your serial output.
this is the lab i was told to get my information from and it is showing that in fig 4 & 5 the circuit is hooked us as i've said. Cathode to the microcontroller and annode toward 3.3v through resistor. I also thought it might be a coding problem when i noticed something. In the lab on the link above, it shows using the SquareWave object, using the Freq() method as Freq(pin, module, freqency) whereas in my copy of SquareWave.spin it shows (module, pin, frequency). Is there 2 different SquareWave.spin objects? I copied and pasted the code (for squarewave.spin) from the PE Labs fundametals pdf.
{{ File: 38khzsignalmonitor.spin This object uses a 38khz IR detector to monitor for carrier signals with data inside them. }} CON _clkmode = xtal1 + pll16x _xinfreq = 5_000_000 STOP_BIT = 4800 ' Stopbit width in clock ticks START_BIT = 2400 ' Startbit width in clock ticks LOW_BIT = 600 ' Lowbit width in clock ticks HIGH_BIT = 1200 ' Highbit width in clock ticks REST_PER = 600 ' Resting period in between pulses (pulled high so no signal transmission) OBJ Debug : "FullDuplexSerial" PUB MonitorSignal(DETECTORpin) | widthTime, index, data, tmp Debug.start(31, 30, 0, 57600) ' Setup the serial terminal for displaying the data. repeat ' Repeat indefinately widthTime := 0 ' Set width time to 0 repeat until ina[noparse][[/noparse]DETECTORpin]~ ' Wait until input from detectorpin is low. repeat while ina[noparse][[/noparse]DETECTORpin]~ ' Increment width time while the pin is held widthTime++ ' to a low value. (indicates signal comming through) if widthTime == START_BIT ' Check to see if the current signal is the start bit. index := 0 repeat 5 ' Repeat 5 times widthTime := 0 ' Reset widthtime. repeat until ina[noparse][[/noparse]DETECTORpin]~ ' Wait until detecotrpin goes low again repeat while ina[noparse][[/noparse]DETECTORpin]~ ' Count up widthtime while detector pin is low widthTime++ if widthTime == LOW_BIT ' If we got a low bit then set data[noparse][[/noparse]index] to 0 data[noparse][[/noparse]index]~ elseif widthTime == HIGH_BIT ' If we got a high bit then set data[noparse][[/noparse]index] to 1 data[noparse][[/noparse]index]~~ index++ ' Increment index. widthTime := 0 repeat until ina[noparse][[/noparse]DETECTORpin]~ repeat while ina[noparse][[/noparse]DETECTORpin]~ widthTime++ if widthTime == STOP_BIT 'cmpData := data[noparse][[/noparse]0..4] repeat tmp from 0 to 4 Debug.bin(data[noparse][[/noparse]tmp],5)▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔
Post Edited (morris4019) : 5/26/2009 10:09:47 PM GMT
I'm not sure about your timing. Your comments indicate timing in clock ticks, but the timing itself is done by incrementing in a loop without reference to the clock. Also, I'm a little concerned that if you do mean clock ticks, your data rate is much too fast for a 38KHz carrier. For example, a 600-tick low bit, is only 7.5us long at 80MHz. That's shorter than one period of your carrier.
Can you also show your transmit program?
{{ File: 38khzsignalwithdata.spin This object will setup a cog to generate a 38khz signal and transmit data through an IR LED. }} CON _clkmode = xtal1 + pll16x _xinfreq = 5_000_000 STOP_BIT = 4800 ' Stopbit width in clock ticks START_BIT = 2400 ' Startbit width in clock ticks LOW_BIT = 600 ' Lowbit width in clock ticks HIGH_BIT = 1200 ' Highbit width in clock ticks REST_PER = 600 ' Resting period in between pulses (pulled high so no signal transmission) VAR long cog long signalStack[noparse][[/noparse]50] OBJ sqWv : "SquareWave" PUB Start(pin) Stop ' Stop any cogs that may be under control cog := cognew(SendData(pin), @signalStack[noparse][[/noparse]0]) PUB Stop if cog <> 0 cogstop(cog) PRI SendData(IREDpin) | us, rep, widthTime dira[noparse][[/noparse]IREDpin]~~ us := clkfreq/1_000_000 ' Set a varible us to equal 1 micro second. repeat rep := 0 outa[noparse][[/noparse]IREDpin]~~ ' Hold IRED pin high so that no signal is generated. sqWv.Freq(0, IREDpin, 38000) ' Setup the square wave frequency to be generated. The square wave will output ' automatically when the output pin is pulled low. repeat rep from 1 to 7 widthTime := lookup(rep : START_BIT*us, HIGH_BIT*us, LOW_BIT*us, HIGH_BIT*us, LOW_BIT*us, HIGH_BIT*us, STOP_BIT*us) outa[noparse][[/noparse]IREDpin]~ ' Start the square wave. waitcnt(widthTime + cnt) ' Pause for respective duration. outa[noparse][[/noparse]IREDpin]~~ ' Pull high and rest waitcnt(REST_PER + cnt) ' Wait for the REST_PER duration.I hope i'm not completely wrong.
There are two main problems that I see with the receive program:
1. You're not measuring pulses in terms of absolute time, but in terms of cycles through a Spin loop. You need to involve cnt in these measurements to get the actual time.
2. You are checking for absolute equality in your comparisons between the measured times and the required times for each different kind of pulse. True equality will almost never hold. What you need to do is compare each against a range of values. If it's within the range, then it's that kind of pulse.
{{ File: 38khzsignalmonitor.spin This object uses a 38khz IR detector to monitor for carrier signals with data inside them. }} CON _clkmode = xtal1 + pll16x _xinfreq = 5_000_000 STOP_BIT = 4800 ' Stopbit width in clock ticks START_BIT = 2400 ' Startbit width in clock ticks LOW_BIT = 600 ' Lowbit width in clock ticks HIGH_BIT = 1200 ' Highbit width in clock ticks REST_PER = 600 ' Resting period in between pulses (pulled high so no signal transmission) VAR long cog long monitorStack[noparse][[/noparse]100] OBJ Debug : "FullDuplexSerialPlus" PUB Start(MonitorPin) Stop ' Stop any cogs that may be under control cog := cognew(MonitorSignal(MonitorPin), @monitorStack[noparse][[/noparse]0]) PUB Stop if cog <> 0 cogstop(cog) PRI MonitorSignal(DETECTORpin) | widthTime, index, data, t,tmp, us us := clkfreq/1_000_000 Debug.start(31, 30, 0, 230400) ' Setup the serial terminal for displaying the data. repeat ' Repeat indefinately repeat until ina[noparse][[/noparse]DETECTORpin]~ ' Wait until input from detectorpin is low. t := cnt ' Set t variable to equal the cnt time when pin went low repeat while ina[noparse][[/noparse]DETECTORpin]~ ' Incrementing cnt while the pin is held ' to a low value. (indicates signal comming through) widthTime := cnt - t ' Calculate total cnt time that pin was low Debug.dec(widthTime/us) Debug.str(String(13)) if ((widthTime/us) > (START_BIT - 1000)) & ((widthTime/us) < (START_BIT + 1000)) ' Check to see if the current signal is the start bit. index := 0 repeat 5 ' Repeat 5 times repeat until ina[noparse][[/noparse]DETECTORpin]~ ' Wait until detecotrpin goes low again t := cnt ' Set variable t to equal the cnt time when detector went low. repeat while ina[noparse][[/noparse]DETECTORpin]~ ' Count up widthtime while detector pin is low widthTime := cnt - t ' Calculate total cnt time that pin was low 'Check to see if we have a low bit, if it is set 'corresponding value to 0. if ((widthTime/us) > (LOW_BIT - 1000)) & ((widthTime/us) < (LOW_BIT + 1000)) data[noparse][[/noparse]index]~ 'Check to see if we have a high bit, if it is set 'corresponding value to 1 elseif ((widthTime/us) > (HIGH_BIT - 1000)) & ((widthTime/us) < (HIGH_BIT + 1000)) data[noparse][[/noparse]index]~~ index++ ' Increment index. repeat until ina[noparse][[/noparse]DETECTORpin]~ t := cnt ' Set t variable to equal the cnt time when pin went low repeat while ina[noparse][[/noparse]DETECTORpin]~ widthTime := cnt - t ' Calculate the total time that pin was low. ' Make sure we got the stop bit before displaying the data. if ((widthTime/us) > (STOP_BIT - 1000)) & ((widthTime/us) < (STOP_BIT + 1000)) repeat tmp from 0 to 4 Debug.bin(data[noparse][[/noparse]tmp],5)▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔
Thanks again!
-Mike
Good news: it works great up to 2400 baud. This is not fast by anyone's standard but probably faster than manually decoding in Spin and allows you to use simple_serial or fullduplexserial on the receiver side of your project.
[noparse][[/noparse]Edit] Since the IR baud rate is so low I added a version (not buffered, using code from simple_serial) that doesn't require another cog.
Post Edited (JonnyMac) : 5/28/2009 12:08:43 AM GMT
The top houses 4 IR Emitters, later on the other 4 sides IR Detectors will be mounted so that it can send and recieve. 2 Buttons, 1 to cycle through the beacon ID it transmitss, and 1 to start and stop the transmission. Also, there is a toggle switch mounted on back to turn the whole system on and off. The pictures are with the top removed.
Thanks everyone for all of your help.
-Mike
Post Edited (morris4019) : 6/9/2009 2:46:17 AM GMT
The LEDs seem to have a low duty cycle that keeps them from burning out from
going way over the rated drive current of the LEDs. (you can see the flashes in a camcorder viewfinder, they look pretty bright)
But if you keep the duty cycle low enough to massively overdrive your IR LEDs for
greater range you would need to keep the data rate low...but that would be OK if
you don't need to send data really fast. If the rate was low enough you could probably
put several amps through the LEDs and not destroy them. If your code burped and the
LEDs stayed on more than a fraction of a second though they would probably make
smoke
receiver because it probably needs a 38khz pulse long enough to make it through
a narrow filter centered on 38khz....I just don't know if this would effect detection of
very short pulses.
You could slowly modulate an LED by switching on/off a carrier at 38khz and sending
1 VERY short burst for 0 and two closely spaced bursts for 1. I just tried this with an
ultrabright white LED keyed by a pulse generator. The amount of light was astounding..like
a strobe light at a club. The LED did not seem to suffer damage. The calculated drive power was well over an amp.
duration of the pulse was approx 1ms....using an old board I made last year using an Atmega168
that drives a dc motor using pwm.... I just twiddled the code to give 1ms single and double pulses
and cranked up the drive voltage to the transistor.
