hi I'm trYing to run 3 stepper motor with a basic stamp home work board and darlintons I'm only able to run one please any body help me with the code and conection
This was the code that I was using it work only for one motor but I need 3 motor
File...... Stepper_27964.BS2
' Purpose... Simple Stepper Motor Demo
' Author.... Parallax, Inc. (Copyright (c) 2004, All Rights Reserved)
' E-mail.... support@parallax.com
' Started...
' Updated... 18 MAR 2004
' {$STAMP BS2}
' {$PBASIC 2.5}
[noparse][[/noparse] Program Description ]
' Simple stepper motor (Parallax #27964) demonstration rotates motor one
' full revolution clockwise, pauses, then rotates one full revolution
' counter-clockwise. After another short pause, the process repeats.
' Connections:
' P4 -> ULN2003.1, ULN2003.16 -> Phase 1 (Black)
' P5 -> ULN2003.2, ULN2003.15 -> Phase 2 (Orange)
' P6 -> ULN2003.3, ULN2003.14 -> Phase 3 (Brown)
' P7 -> ULN2003.4, ULN2003.13 -> Phase 4 (Yellow)
' Note: Do NOT connect stepper motor wires directly to the BASIC Stamp.
' See Parallax documentation for complete connection schematic.
[noparse][[/noparse] Revision History ]
[noparse][[/noparse] I/O Definitions ]
Phase VAR OUTB ' phase control outputs
[noparse][[/noparse] Constants ]
[noparse][[/noparse] Variables ]
idx VAR Byte ' loop counter
stpIdx VAR Nib ' step pointer
stpDelay VAR Byte ' delay for speed control
[noparse][[/noparse] EEPROM Data ]
Steps DATA %0011, %0110, %1100, %1001
[noparse][[/noparse] Initialization ]
Setup:
DIRB = %1111 ' make P4..P7 outputs
stpDelay = 15 ' set step delay
[noparse][[/noparse] Program Code ]
Main:
FOR idx = 1 TO 48 ' one revolution
GOSUB Step_Fwd ' rotate clockwise
NEXT
PAUSE 500 ' wait 1/2 second
GOSUB Step_Rev ' rotate counter-clockwise
NEXT
GOTO Main
END
[noparse][[/noparse] Subroutines ]
' Turn stepper clockwise one full step (7.5 degrees)
Step_Fwd:
stpIdx = stpIdx + 1 // 4 ' point to next step
GOTO Do_Step
' Turn stepper counter-clockwise one full step (7.5 degrees)
Step_Rev:
stpIdx = stpIdx + 3 // 4 ' point to previous step
GOTO Do_Step
' Read new step data and output to pins
Do_Step:
READ (Steps + stpIdx), Phase ' output new phase data
PAUSE stpDelay ' pause between steps
RETURN
Here is a simple modification to your code.
The steppers are connected to ports A, B and C.
And the Phase value ( original code ) is just copied to these ports.
It does not do anything fancy. It runs all steppers in same fashion - forward and backwards.
Of course you could run them independently·with some more changes to your code.
You·could use array of Phase instead of individual port assigments.
Have fun "coding".
PS I use BS2E and have not changed the processor selection back to·yours.
Whoops, I forgot to change the output direction!
Unless there is a conflict just do DIRS = $FFFF
Post Edited (vaclav_sal) : 5/17/2009 12:43:57 AM GMT
I'm trying the code that you gave me but it not working and I'm using one darlington ULN2803A for each motor Idont know if I'm conecting it rigth can you help me please
Hears the code I used for a demo it uses DIRB,C,D.... I had a thread on hear asking for help on this 1 but it only ended up being a typo problem. Here's the link
- Stephen
thanks
- Stephen
' Started...
' {$STAMP BS2}
' {$PBASIC 2.5}
' Connections:
Setup:
Main:
NEXT
NEXT
GOTO Main
END
Step_Fwd:
GOTO Do_Step
Step_Rev:
GOTO Do_Step
Do_Step:
RETURN
Have fun "coding".
Leon
Amateur radio callsign: G1HSM
Suzuki SV1000S motorcycle
