Accelerometer Data Logging
I am looking to log Acceleration data with respect to time using the 3Axis, Propeller, and my laptop in my car. Is there a good way to do this?
I am currently working on hacking the Accelerometer Demo to work off DuplexSerialPlus rather than VGA and somehow export the data.
I'd like to get the data into Excel, probably by somehow outputting Comma Separated Values in a txt file or something similar.
The goal is to see how quickly the G's tansfer from Throttle to Brakes, and turning one side to the other, as well as how high G's a car pulls when cresting a hill or climbing through a trough.
Any advice? I am very new to Propeller.
I'll see if I can find out how to throw the Spin code in here. I changed the 3Axis and the Tick Tock object.
{{ ********************************************* * H48C Tri-Axis Accelerometer VGA_DEMO V1.1 * * Author: Beau Schwabe * * Copyright (c) 2008 Parallax * * See end of file for terms of use. * ********************************************* Revision History: Version 1.0 - (Sept. 2006) - Initial release with a TV mode 3D-graphics cube Version 1.1 - (March 2008) - 3D-graphics cube removed - Basic VGA mode display used instead of TV - Added 600nS padding delay around Clock rise and fall times }} { 220Ω ┌──────────┐ P2 ──│1 ‣‣••6│── +5V P0 = CS 220Ω │ ┌°───┐ │ 220Ω P1 = DIO P1 ──│2 │ /\ │ 5│── P0 P2 = CLK │ └────┘ │ 220Ω VSS ──│3  4│── Zero-G └──────────┘ Note1: Zero-G output not used in this demo Note2: orientation Z Y  │ / / °/  reference mark on H48C Chip, not white dot on 6-Pin module │ / / / │/ o  white reference mark on 6-Pin module indicating Pin #1 ──── X ThetaA - Angle relation between X and Y ThetaB - Angle relation between X and Z ThetaC - Angle relation between Z and Y Note3: The H48C should be powered with a 5V supply. It has an internal regulator that regulates the voltage down to 3.3V where Vref is set to 1/2 of the 3.3V In this object, the axis is already compensated with regard to Vref. Because of this, the formulas are slightly different (simplified) compared to what is stated in the online documentation. G = ( axis / 4095 ) x ( 3.3 / 0.3663 ) or G = axis x 0.0022 or G = axis / 455 An expected return value from each axis would range between ±1365. i.e. ±455 would represent ±1g ±910 would represent ±2g ±1365 would represent ±3g } CON _CLKMODE = XTAL1 + PLL16X _XINFREQ = 5_000_000 CS = 0 DIO = 1 CLK = 2 VAR long vref,x,y,z,ThetaA,ThetaB,ThetaC,days,hours,minutes,seconds OBJ H48C : "H48C Tri-Axis Accelerometer" Dup : "FullDuplexSerialPlus" Time : "TickTock2" PUB DEMO_TEST 'start and setup Accelerometer waitcnt(clkfreq*2 + cnt) H48C.start(CS,DIO,CLK) Dup.start(31, 30, 0, 57600) Time.start(0, 0, 0, 0) Dup.tx(16) repeat 'vref := (H48C.vref*825)/1024 '<-- Here's how to get vref in mV vref := H48C.vref '<-- Here's how to get vref in RAW 'Note: The returned value for X, Y, and Z is equal to the axis - Vref x := H48C.x*100/455 '<-- Here's how to get x y := H48C.y*100/455 '<-- Here's how to get y z := H48C.z*100/455 '<-- Here's how to get z 'Note: The returned value is in Deg (0-359) 'remove the '*45)/1024' to return the 13-Bit Angle ThetaA := (H48C.ThetaA*45)/1024 '<-- ThetaA is the angle relationship between X and Y ThetaB := (H48C.ThetaB*45)/1024 '<-- ThetaB is the angle relationship between X and Z ThetaC := (H48C.ThetaC*45)/1024 '<-- ThetaC is the angle relationship between Y and Z 'Dup.Str(String("X ")) Time.Get(@days, @hours, @minutes, @seconds) Dup.Dec(seconds) Dup.Str(String(", ")) Dup.Dec(x) Dup.Str(String(", ")) 'Dup.Str(String(13, "Y ")) Dup.Dec(y) Dup.Str(String(", ")) 'Dup.Str(String(13, "Z ")) Dup.Dec(z) Dup.Str(String(13)) 'Dup.Str(String(13, "ThetaA ")) 'Dup.Dec(ThetaA) 'Dup.Str(String(13, "ThetaB ")) 'Dup.Dec(ThetaB) 'Dup.Str(String(13, "ThetaC ")) 'Dup.Dec(ThetaC) waitcnt(clkfreq/10 + cnt) 'Dup.tx(16)Then for the edited Tick Tock:
'' From Parallax Inc. Propeller Education Kit - 6: Objects Lab ''File: TickTock.spin VAR long stack[noparse][[/noparse]50] byte cog long days, hours, minutes, seconds PUB Start(setDay, setHour, setMinutes, setSeconds) : success {{ Track time in another cog. Parameters - starting values for: setDay - day setHour - hour setMinutes - minute setSeconds - second }} days := setDay hours := setHour minutes := setMinutes seconds := setSeconds Stop cog := cognew(GoodTimeCount, @stack) success := cog + 1 PUB Stop ''Stop counting time. if Cog cogstop(Cog~ - 1) PUB Get(dayAddr, hourAddr, minAddr, secAddr) | time {{ Get the current time. Values are loaded into variables at the addresses provided to the method parameters. Parameters: dayAddr - day variable address hourAddr - hour variable address minAddr - minute variable address secAddr - secondAddress }} long[noparse][[/noparse]dayAddr] := days long[noparse][[/noparse]hourAddr] := hours long[noparse][[/noparse]minAddr] := minutes long[noparse][[/noparse]secAddr] := seconds PRI GoodTimeCount | dT, T dT := clkfreq/10 T := cnt repeat T += dT waitcnt(T) seconds ++Post Edited (rough_wood) : 5/25/2009 5:45:02 AM GMT
