Windows Bitmap viewer for TV
I've hacked TV.SPIN to bring you a Windows BMP picture viewer for the Propeller!
It can display any 256 color (8bpp) .BMP file up to 256 pixels wide and 192 pixels tall.
(but bmp filesize should be less than around·27,828 bytes)
Regular text shows on top of the screen and picture on the bottom.
Here·the code, ·screenshot, and source .bmp file:
(Of course, I've done some magic in Photoshop to optimize the result)
My Prop Info&Apps: ·http://www.rayslogic.com/propeller/propeller.htm
Post Edited (Rayman) : 5/23/2009 9:18:12 PM GMT
OBC
New to the Propeller?
Also, here are a few images I've tweaked in Photoshop (and a couple untweaked, just to test).
Nice work, looks really good!!!
Have any tips for creating the bmp files, a couple I tried crashed the application.
(They were less than 256x192 and 256 colours)
Coley
PropGFX - The home of the Hybrid Development System and PropGFX Lite
Also, it's really best to use the same palette as the examples for best quality.
Also, I must admit that I haven't really tried 256 wide or 192 tall...· Maybe there's a problem with tall or wide pics?
Post Edited (Rayman) : 5/23/2009 9:19:32 PM GMT
I think it was me just being lazy and using windows paint.
I used paint.net to adjust the attached file, work really well now ....
Coley
135x192 256 Colours
PS:· Do you think this would work with a PAL TV?
Yes that does look a bit better.
PAL mode works but flickers/shimmers far too much, I can tweak the driver to do PAL 60 which is pretty much the same as NTSC.
How did you apply the TV Palette in photoshop, a little tutorial would be nice....
Coley
This is a bit of a complication for my video player plan...
Post Edited (Rayman) : 5/30/2009 12:59:22 AM GMT
You can try here: http://www.brothersoft.com/paint-shop-pro-64054.html
Duffer
