Figuring voltage from an current sense coil?
I have to admit, I'm not sure where to start, so I figured the guru's here could point me in a direction.
First let me explain what I'm trying to do. There is a system which produces pulses on a wire at 2500-6000 Hz, with a voltage of about 290 volts. I would like to read the frequency of this wire.
I'm pretty sure I do not want to interface with this wire directly, but thought about using a sensor coil. I'm lost as to figuring the limiting resistor for the opto isolator from the coil. I'm being very careful about this voltage (or noise) getting into my circuitry, so I'm using a sense coil to an opto-isolator which I'll be reading the output of.
How does one figure the voltage from a sense coil. Is it a simple matter of actually reading the voltage from a meter, or can it done (relatively close), with just math?
James L
James L
Partner/Designer
Lil Brother SMT Assembly Services
Please note: Due to economic conditions the light at the end of the tunnel will be turned off until further notice. Thanks for your understanding.
James L
James L
Partner/Designer
The more you learn, the more you find you don't know. it is neverending.
Any other thoughts??
James L
James L
Partner/Designer
Just a crude test... can you place a nearby AM radio and "hear" the frequency ... If so then there may be a simple Op-Amp configuration that might work in your application by just placing a piece of wire next to your signal wire.
Beau Schwabe
IC Layout Engineer
Or were you talking about something totally different, Beau?
No, that's along the lines of what I was thinking. I'm doing a full system upgrade to my laptop over the long weekend right now or else I would provide a schematic. There is an Op-Amp configuration I am thinking of that doesn't get used much, that would be perfect in a situation like this.
Beau Schwabe
IC Layout Engineer
Here is a test circuit... you should be able to go down to just a few milli-Volts of fluctuation on the input that will provide a full 5V swing on the output. A small piece of wire (6 inches or so) in parallel with the signal wire should be enough to detect a signal. Keep the circuit as straightline as possible and keep the output as far away from the input as possible. Leads from the input should be as close to the first stage Op-Amp as possible, this is after all the "signal tracer probe".
Beau Schwabe
IC Layout Engineer
