LED not working plz help!
hey guys.
im trying to get this LED to work but its not i think i just need a different resistor
heres a link to the specs of the LED and resistor
http://i214.photobucket.com/albums/cc297/puzzlesasuke/IMG_3128.jpg
any help would be really appreciated
im new to this forum so idk where i should post this, so sorry if this is the wrong place
Your question is not about robotics. A better place would be The Sandbox. If you're trying to use this LED with a Stamp, then the Stamp forum is appropriate, etc.
the end project will look like this
http://i214.photobucket.com/albums/cc297/puzzlesasuke/End_Product.jpg
oh okay ill keep that in mind next time im going to post thanks
If you want to run this LED off a 6V battery, try a 100 Ohm resistor for a 2V drop at 20mA. From one link you provided, it looks like the measured forward voltage is about 3.8V at 20mA and I'm basing the resistor values on that.
If you want to switch the LED on and off using a microcontroller, try a 47 Ohm resistor in series with the LED with the anode of the LED connected to the resistor and the other end of the resistor to a Stamp I/O pin. The cathode of the LED should be connected to ground (Vss).
