I have some DC motors that I have no idea what the specs are on them. Is there any code that could help determine what the RPM is while they are running?
It's not so much a matter of code. You need some kind of sensor that would attach to the motor shaft and provide a pulse for each revolution of the shaft. A Stamp could count these pulses with a COUNT statement and display the result converted to RPM.
Typical sensors for this include using a LED and phototransistor with a little metal or plastic "flag" attached to the motor shaft that interrupts the light beam from the LED or a little magnet attached to the motor shaft and a Hall-effect sensor that produces a pulse whenever the magnet passes next to the sensor.
In the past I have used a small DC motor as a generator and hooked it to a meter. Use a motor with a known RPM and record the voltage. Do the math from there. Tachs in industrial servos are basicly DC motors. Don't know if brushless DC motors will work. This is old school.
Leon
Amateur radio callsign: G1HSM
Suzuki SV1000S motorcycle
