asm prop
i'm tring to to read a number bytes-words-longs from the hub mem to a cog running in asm
these bytes-words-longs·in the hub·will be contoled by a spin program running in another cog
the total number bytes-words-longs· will be 16
thank you bkb
thank you bkb
Use RDBYTE, RDWORD or RDLONG in assembly to read HUB ram.
Bean.
There is a fine line between arrogance and confidence. Make sure you don't cross it...
