need help on programming a max522 dac
·i was wondering· would anyone·have some basic stamp2· code that i could program a max522 dac with.i am wanting·· to send a number from the bs2 and then have it converted to an analog voltage which· will be read by using a digital meter,really in the dark on this one any help would be welcomed
If you look at the PWM command in the helpfile of the programming environment, you'll see how to use the command with a small capacitor to get an analog voltage.
Cheers,
Tom Sisk
http://www.siskconsult.com
