IR sensor
Hi there!
I designed a circuit (on a breadboard). The circuit consists of an IR led - as a transmitter and a TSOP1740 as a receiver. I want to insert the IR transmitter in a small room, but because of the walls the receiver detects signal all the time. The one pin of IR led is connected to an input in basic stamp 2 (on/off function) and the other pin is connected to an input through a 430 Ω resistance to another input in basic stamp 2.
What could i do so the signal does not detect the walls as an obstacle? Or how could i reduce the emitting distance of the IR led?
Thanks in advance
Thanks in advance
Thank you very much for the solution!
