assembly programming and the vga_512x384_bitmap obj
tonyp12
UPDATE: further down is a TEXT SCROLLER.
A short little routine that does a good job, and is·helpful to learn from.
Just had the propeller for a few days.
I'm skipping Spin and go directly to pasm.
Here is·my first·VGA test, it's simple so it's easy to learn from.
1: Fills the color blocks with red/dark_blue
2: put in 16 columns, 64 pixels high.
3: rotate them in sync with monitor display.
Any veterans that have inputs what should have been done in better way?
Post Edited (tonyp12) : 5/24/2009 11:43:24 PM GMT
CON
_clkmode = xtal1 + pll16x
_xinfreq = 5_000_000
tiles = vga#xtiles * vga#ytiles
tiles32 = tiles * 32
OBJ
vga : "vga_512x384_bitmap"
VAR
long sync, pixels[noparse][[/noparse]tiles32]
word colors[noparse][[/noparse]tiles]
PUB start | h, i, j, k, x, y
'start vga
vga.start(16, @colors, @pixels, @sync)
'implant pointers and launch assembly program into COG
asm_colors := @colors
asm_pixels := @pixels
asm_sync := @sync
cognew(@asm_entry, 0)
DAT '
' Assembly program
org
asm_entry mov counter, #192 '192 words to write
:loop wrword palette,asm_colors 'write to hub ram, one time setup rutine.
add asm_colors, #2 'move forward 2 bytes
djnz counter, #:loop
main
mov counter, #16 '16 longs wide is one horisontal line
shl counter, #6 'multiply with 64
mov asm_pixpntr,asm_pixels 'buffer the asm_pixels pointer
:loop wrlong pix_data, asm_pixpntr 'write long for 32 pixels.
add asm_pixpntr, #4 'move forward 4 bytes
:waitforsync rdlong sync_clear, asm_sync wz 'read long from hub ram and do a zero flag check
if_z jmp #:waitforsync 'if zero, test again.
mov sync_clear, #0 'reset it,
wrlong sync_clear,asm_sync 'write long to hub ram
rol pix_data, #1 'rotate pixel dat left, as lsb is first it will look ror
jmp #main
asm_colors long 0 'pixel base (set at runtime)
asm_pixels long 0 'pixel base (set at runtime)
asm_sync long 0 'sync (set at runtime)
asm_pixpntr long 0 'buffer for asm_pixels pointer
palette long %100000 <<10 + %000001 <<2 'RrGgBbxx + RrGgBbxx (forground and background colors)
pix_data long $000000ff
sync_clear res 1
counter res 1
I don't know if it is of interest for you. Just my $.02...
Airspace V - international hangar flying!
www.airspace-v.com/ggadgets for tools & toys
I posted it on youtube
[url=mhtml:{4C6317E7-E7BB-490B-92C7-AF4FA83717C3}mid://00000001/!x-usc:http://www.youtube.com/watch?v=GWViWCxK_SM]
I can NOT find a 4 color bitmap driver on the OBJ exchange?
And one have·source for that?
preferable just a modified version of·the vga_512x384_bitmap obj
320 pixels/8*2· *240 pixels =··19kb for pixel data
Post Edited (tonyp12) : 5/20/2009 7:58:12 PM GMT
Reads a letter in cog ram, finds the corresponding font bitmap in ROM.
Get rid of the interleaving.
the result: http://www.youtube.com/watch?v=dtahz8WwBm0
[color=black]CON[/color] [color=black] _clkmode = xtal1 + pll16x _xinfreq = 5_000_000[/color] [color=black] tiles = vga#xtiles * vga#ytiles tiles32 = tiles * 32[/color] [color=black]OBJ[/color] [color=black] vga : "vga_512x384_bitmap"[/color] [color=black]VAR[/color] [color=black] long sync, pixels[noparse][[/noparse]tiles32] word colors[noparse][[/noparse]tiles][/color] [color=black]PUB start | h, i, j, k, x, y[/color] [color=black] 'start vga vga.start(16, @colors, @pixels, @sync)[/color] [color=black] 'implant pointers and launch assembly program into COG asm_colors := @colors asm_pixels := @pixels asm_sync := @sync cognew(@asm_entry, 0)[/color] [color=black]DAT ' ' ' Assembly program ' org asm_entry mov counter1, #192 '192 words to write mov asm_colpnt, asm_colors 'buffer the asm_color pointer :loop wrword palette,asm_colpnt 'write to hub ram. add asm_colpnt, #2 'move forward 2 bytes djnz counter1, #:loop [/color] [color=black]main mov counter1, #16 '16 chars per line mov asm_pixpntr,asm_pixels 'buffer the asm_pixels pointer :loop1 mov fontpnt, text 'init font pointer add :loop1,#1 'self modifying code, increase text pointer. shr fontpnt, #1 wc 'no odd numbers please, but let me know if it was. shl fontpnt, #7 'multiply by 64 plus counteract the SHR above add fontpnt, fontmap 'add $8000 mov counter2, #32 '32 pixels tall [/color] [color=black]:loop2 rdlong pix_data, fontpnt 'read from Hub-ROM if_nc and pix_data, mask1 'it was an even number (checked 5 lines above) if_c and pix_data, mask2 'it was an odd number (get rid of interleaving) mov pix_data2, pix_data 'make a copy of the font if_nc shl pix_data2, #1 'if even, shift the copy left 1 pixel if_c shr pix_data2, #1 'if odd, shift the copy right 1 pixel or pix_data,pix_data2 'mix them togheter. wrlong pix_data, asm_pixpntr 'write long to hub ram for 32 pixels. add asm_pixpntr, #64 'move forward 64 bytes add fontpnt, #4 'next long djnz counter2, #:loop2 sub asm_pixpntr, nextblock 'counteract all the #64 we added djnz counter1, #:loop1 [/color] [color=black]waitforsync rdlong sync_clear, asm_sync wz 'read long from hub ram and with a zero flag check if_z jmp #waitforsync 'if zero, test again. mov sync_clear, #0 'reset it, wrlong sync_clear,asm_sync 'write long to hub ram mov counter1, #16 mov asm_colpnt, asm_colors add asm_colpnt,#32 movs palette, #%11111000 sub palette, palette_cnt djnz palette_cnt, #:loop mov palette_cnt, #200 :loop wrword palette,asm_colpnt 'write to hub ram add palette, #4 add asm_colpnt, #2 'move forward 2 bytes djnz counter1, #:loop jmp #waitforsync[/color] [color=black]asm_colors long 0 'pixel base (set at runtime) asm_colpnt long 0 ' asm_pixels long 0 'pixel base (set at runtime) asm_sync long 0 'sync (set at runtime) asm_pixpntr long 0 'buffer for asm_pixels pointer[/color] [color=black]palette long %100000 <<10 + %000001 <<2 'RrGgBbxx + RrGgBbxx (forground and background colors) palette_cnt long 200[/color] [color=black]pix_data long 0 pix_data2 long 0 nextblock long 64*32-4 'move back the pixel pointer to where you started + one long fontmap long $8000 fontpnt long 0 mask1 long %01010101_01010101_01010101_01010101 mask2 long %10101010_10101010_10101010_10101010[/color] [color=black]text long "Hi I'm PROPELLER" [/color] [color=black]sync_clear res 1 counter1 res 1 counter2 res 1 [/color] [url=http://www.youtube.com/watch?v=dtahz8WwBm0][/url]A Text Scroller.
In a·clever way it uses RCR for both shifting and insertion of font bits.
The result: http://www.youtube.com/watch?v=dZZMfN2loAg
[color=black]CON[/color] [color=black] _clkmode = xtal1 + pll16x _xinfreq = 5_000_000[/color] [color=black] tiles = vga#xtiles * vga#ytiles tiles32 = tiles * 32[/color] [color=black]OBJ[/color] [color=black] vga : "vga_512x384_bitmap"[/color] [color=black]VAR[/color] [color=black] long sync, pixels[noparse][[/noparse]tiles32] word colors[noparse][[/noparse]tiles][/color] [color=black]PUB start | h, i, j, k, x, y[/color] [color=black] 'start vga vga.start(16, @colors, @pixels, @sync)[/color] [color=black] 'implant pointers and launch assembly program into COG asm_colors := @colors asm_pixels := @pixels asm_sync := @sync cognew(@asm_entry, 0)[/color] [color=black]DAT ' ' ' Assembly program ' org asm_entry mov counter1, #192 '192 words to write :loop wrword palette,asm_colors 'write to hub ram. add asm_colors , #2 'move forward 2 bytes djnz counter1, #:loop scroller mov fontpntr, text wz 'init font pointer add scroller, #1 'self modifying code if_z movs scroller, #text 'reset text pointer if_z mov fontpntr, #32 'use space mov mask, #%01 shr fontpntr, #1 wc 'no odd numbers please, but let me know if it was.[/color] [color=black] if_c mov mask, #%10 shl fontpntr, #7 'multiply by 64 plus counteract the SHR above add fontpntr,fontrom 'adds $8000 +127 :waitforsync rdlong sync_clear, asm_sync wz 'read long from hub ram and with a zero flag check if_z jmp #:waitforsync 'if zero, test again. mov sync_clear, #0 'reset it, wrlong sync_clear,asm_sync 'write long to hub ram[/color] [color=black] mov asm_pixpntr, asm_pixels 'buffer the asm_pixel pointer add asm_pixpntr, block 'start in a lower right corner mov counter1, #256 shl counter1, #1 'make it 512[/color] [color=black]:loop rdlong pix_data, asm_pixpntr test counter1, #%1111 wz 'only happens every other 16 times if_z rdlong pix_data2,fontpntr 'read font ROM in hub if_z sub fontpntr,#4 'move up one line for next time if_z test pix_data2,mask wc 'set c flag if a 1, as 1 it's an odd number of bits. rcr pix_data, #1 wc [b]'shift right with carry flag[/b], use #2 for double speed/wide font wrlong pix_data, asm_pixpntr 'write to the bitmap in hub sub asm_pixpntr, #4 'move backwards 4 bytes djnz counter1, #:loop add fontpntr, #128 'counteract all the the sub4 that was done 32 times. [/color] [color=black] shl mask,#2 wz 'shift left, z flag if you shifted youself out to zero if_nz jmp #:waitforsync 'if it was not zero, just wait for sync and use same font. jmp #scroller [/color] [color=black]asm_colors long 0 'pixel base (set at runtime) ' asm_pixels long 0 'pixel base (set at runtime) asm_sync long 0 'sync (set at runtime) palette long %100000 <<10 + %000001 <<2 'RrGgBbxx + RrGgBbxx (forground and background colors) block long 64*32*3-4 'start at 3 blocks down, line31 right side fontrom long $8000+127 'ROM location$8000 plus start 31 lines down text long " I have been impressed with the urgency of doing. Knowing is not enough; we must apply." long " Being willing is not enough; we must do. ( Leonardo da Vinci )" long " We have to do the best we can. This is our sacred human responsibility. (Albert Einstein)",0 asm_pixpntr res 1 'buffer for asm_pixels pointer pix_data res 1 'buffer for vga bitmap pix_data2 res 1 'buffer for font bits mask res 1 'the rolling mask sync_clear res 1 counter1 res 1 fontpntr res 1 [/color]Post Edited (tonyp12) : 5/25/2009 1:24:16 AM GMT
