Dip ftdi?
Are there any chips out there that are in a dip package that do the same as the FTDI FT232RQ?
Thanks.
Quit buying all those fixed voltage regulators, and·get an Adjustable Power Supply·for your projects!· Includes an LED testing terminal!
Thanks.
I am desperately looking for one for TAOS TCS3414CS.
So far no luck.
Vaclav
Have a look at this thread ..
http://forums.parallax.com/showthread.php?p=667708
John Twomey
'Necessity is the mother of invention'
Those who can, do.Those who can’t, teach.
Thanks.
and I was referring to the DIP 'FTDI eval' as with image attached .. Don't know where the link you mentioned came from .. The link I mentioned is clickable from my end ?
John
EDIT: - Uploaded a jpg rather than .bmp
Post Edited (QuattroRS4) : 5/18/2009 12:58:36 AM GMT
Have a look at this though - a breakout Board for the FT232R
www.sparkfun.com/commerce/product_info.php?products_id=718
John
Thanks.
Thanks.
Phil,
That is right. One side of the chip is communicating a RS232 signal which is a high voltage (I think it is actually +/- 12 v, but I could be wrong), the other side of the chip communicates at a low voltage signal. The chip itself is transparent to each side, so no protocols are needed for the communication. There are also RS485 chips, which do the same, but the voltage is higher (on the high side).
James L
James L
Partner/Designer
Lil Brother SMT Assembly Services
Please note: Due to economic conditions the light at the end of the tunnel will be turned off until further notice. Thanks for your understanding.
"I'm not so good with chips..." is a poor excuse for not doing any research in today's world of the internet and the vast resources available. There's plenty of basic explanations available for a quick and simple websearch. For most electronics questions, the Wikipedia is a good source.
Thanks.
The Propeller Pro Dev.Board uses a FTDI "FT232RQ"
I could use a DIP version of this chip too.
On a side note. I'm not one to grip but.
Why is it that certain people on this forum feel that it should be Your last ditch effort, when all hope·is lost. And Theirs no other source of info. And its then and·only then, that it·is correct to post a Question in these forums???
Had I ran into this Negative response when I first started using Parallax products, I wouldn't·be here posting this post reply.
Wikipedia didn't get Me to buying stuff from Parallax, But the·Parallax forums did.!
I think these forums should be the first place to look for info for use with the Parallax line up.
___________$WMc%__________
The Truth is out there············································ BoogerWoods, FL. USA
Post Edited ($WMc%) : 5/22/2009 1:32:57 AM GMT
Thanks.
I just may make one of these myself. Vaati, I'm going to make a few of these boards today. If you want the PCB to populate, instead of just a breakout board, I can send one of them. I don't want to cut in on Parallax' business too much, since they are very kind and have always been great to me, SO this would be more of a one time thing.
Thanks.
