Catalina - a C compiler for the Propeller
RossH
All,
Just in case none of your many heads ever reads the other propeller forums, I've released a beta version of my C compiler developed on the Hydra. In keeping with the Hydra spirit, it even includes a demo game - a version of Othello written in C.
Se the main Catalina thread at http://forums.parallax.com/showthread.php?p=795326
Ross.
Post Edited (RossH) : 5/18/2009 6:55:23 AM GMT
Ross.
I've released a new beta of the Catalina C compiler, developed on the Hydra - see http://forums.parallax.com/showthread.php?p=795326.
For those of you with the Hydra Xtreme 512K card, the latest release now supports C programs larger than 32K.
Ross.
humanoido
Post Edited (humanoido) : 5/18/2009 8:59:43 AM GMT
Okay, I'm intrigued - why do you want to run as many different languages as possible?
And do you mean you want to run them all at once (perhaps each using a separate cog?) do you just want a system capable of running them all?
Ross.
some programs that used 3 languages to run some very large
pneumatic robots almost the size of a house.
Three languages added together gave capabilities of each and
the final program was amazing, at least in my mind. Prior to that,
I wrote AI programs that used multiple languages for adding
thinking functions to Japanese CNC machines. It was successful
and I've kept the method ever since.
Now I starting thinking about the challenge of putting as many
languages as possible into the Hydra. I already started the
language collection and have two successfully running. But
your idea is better, to put a language in each cog. But I don't
know how to do that. Do you? If you can open the door for me,
I'm willing to step through.
humanoido
It will take me some time yet, but I'm working on adding true cog-based parallel processing (not simple mutithreading) to Catalina. This would means that each cog could either execute a completely independent Catalina program - or they could all co-operate. Also, I've started looking at adding other languages to Catalina. I can already do BASIC, since there are quite a few simple BASIC interpreters written in C. I may release one shortly as a demo.
Now that Catalina programs are no longer restricted to the Propeller's 32K RAM limit, lots of things have suddenly become possible.
So just wait a while, and check in on the progress of Catalina from time to time!
Ross.
with BASIC language as the first version. Running multiple programs and
languages in cogs will be very useful. But do all these cogs share the same
memory? How will that be handled?
humanoido
The programs will not share memory except when two programs agree to synchronize. At the time of synchronization the programs agree on a set of variables that will be visible to both for the duration of synchronization. This is a model adopted in some multitasking languages (e.g. in Ada it is called a 'rendezvous'). It is a very neat solution that I hope will map efficiently to the Propeller architecture. But it is not built yet [noparse]:)[/noparse]
Ross.
