Word Sized constant in Byte array — Parallax Forums
DynamoBenDynamoBen Posts: 366
edited 2009-05-18 07:11 in Propeller 1
I have several word sized constants that need to be place into a byte array which is subsequently sent via serial. For the life of me I can't figure out how to place both bytes into the array. I've tried bytemove, wordmove, constant.byte[noparse][[/noparse]x], but none of these seem to·work.
Can this be done? If so·how?
    edited 2009-05-17 04:22
    just use x>>8 to get the top half of the word.
    My new unsecure propmod both 1x1 and full size arriving soon.
    Need to upload large images or movies for use in the forum. you can do so at uploader.propmodule.com for free.
  • DynamoBenDynamoBen Posts: 366
    edited 2009-05-17 04:35
    Works perfect, thank you for the quick reply!
    edited 2009-05-17 04:40
    glad I could help.
    edited 2009-05-17 04:50
    DynamoBen,
    Here is another "trick" that avoids using any shifting or math...
    This demonstration uses the lights on the Propeller DEMO board.
    CON
    _clkmode          = xtal1 + pll16x
    _xinfreq          = 5_000_000
    PUB  MainProg
         L0 := %01100001_00110001_00011001_00001101
               W1_highbyte   │   W0_highbyte   │
                        W1_lowbyte        W0_lowbyte
         dira[noparse][[/noparse]16..23]~~
         repeat
           outa[noparse][[/noparse]16..23] := W0_lowbyte
           waitcnt(clkfreq*1+cnt)                           'Wait 1 second
           outa[noparse][[/noparse]16..23] := W0_highbyte
           outa[noparse][[/noparse]16..23] := W1_lowbyte
           outa[noparse][[/noparse]16..23] := W1_highbyte
    DAT
    L0            long
    W0            word
    W0_lowbyte    byte      0
    W0_highbyte   byte      0
    W1            word
    W1_lowbyte    byte      0
    W1_highbyte   byte      0
    Beau Schwabe
    IC Layout Engineer
    edited 2009-05-17 05:31
    Very interesting thanks Beau I may be able to use that.
  • Mike HuseltonMike Huselton Posts: 746
    edited 2009-05-17 08:53
    This also provides an alternative scheme for coding data structures. I'll take any coding "tricks" that I can.
    JMH
    edited 2009-05-17 15:33
    Just an additional note:
    It isn't necessary to setup an entire variable array, you can just create one instance of a LONG defined in the DAT section like I have done...
    DAT
    L0            long
    W0            word
    W0_lowbyte    byte      0
    W0_highbyte   byte      0
    W1            word
    W1_lowbyte    byte      0
    W1_highbyte   byte      0
    ...·From there, if you need to determon what each byte is of a particular LONG, you can do something like ...
    L0 := SomeOtherLongVariable
    ' W1_highbyte, W1_lowbyte, W0_highbyte, W0_lowbyte now hold the ordered bytes that are
    ' associated to SomeOtherLongVariable
    ... You can also use this method in reverse ...
    W0_lowbyte  := %11001100
    W0_highbyte := %10101010
    W1_lowbyte  := %00110011
    W1_highbyte := %01010101
    ' Causes L0 to equal... %01010101_00110011_10101010_11001100
    · ... If you only wanted to affect the upper or lower WORD, then something like this would also work ...
    W0 := %10111101_11100111
    ' This way, W0_highbyte equals %10111101 and W0_lowbyte equals 11100111
    Beau Schwabe
    IC Layout Engineer
    Post Edited (Beau Schwabe (Parallax)) : 5/17/2009 3:46:58 PM GMT
  • MagIO2MagIO2 Posts: 2,243
    But that only works in DAT section, so if you want to write something for the ObjectExchange, please don't do it that way - or at least tell in the Header that this object can only be used as a singleton.
    The way it should also work with variables is:
    CON
       word0 = $aaaa
       word1 = $1111
    VAR
       myVar byte[noparse][[/noparse]10]
    PUB main
       word[noparse][[/noparse] @myVar     ]:=word0
       word[noparse][[/noparse] @myVar + 2 ]:=word1
    You only have to take care of the alignment of the byte array.
