Voltage regulator heat
A quick question about voltage regulators.
I've recently repaired a Professional Development Board by replacing the voltage regulator.
The regulator I replaced it with is the same as what was in there originally (7805a) and I
included the same style of heatsink AND used Artic Silver(the good stuff) thermal paste between
the heat sink and the regulator.
My problem is when I supply the PDB with regulated 12v the regulator gets quite warm to the
touch. Not quite painfully, but pretty close. And it happens quickly as well (less than 5
minutes or so).
I understand that its burning off 7volts of heat, but should I be concerned at all? There seems
to be no sign of thermal shutdown and no sign that it is causing any harm to the surrounding
plastic or circuitry.
Does anyone else run a PDB off 12volts? Is it very warm after just a couple minutes?
PS: The only load I'm running on it is a BS2, an SX and a LCD.
minutes or so).
Now I use switching regulators on all my designs. No heat problems.
My new unsecure propmod both 1x1 and full size arriving soon.
To get some perspective, look at the datasheet for the 7805, particularly the temperature where it begins to shut down. They're designed to operate at a junction temperature up to 125C = 257F. There's some thermal resistance between the chip and the heatsink, but you're using a good thermal paste. The heatsink could get well over the boiling point of water before the regulator shuts down. I suspect your regulator temperature is nowhere near that. Try measuring the temperature of the heatsink.
Remember that Parallax recommends a 12V wall wart as the power source for the PDB, probably because of the L293D and its use as a motor driver. You can always run the PDB from a 9V wall wart and markedly reduce the heat produced by the regulator.
Mctrivia:
I hadn't realized that the max draw would be so low! I had assumed that I could draw the full 1.5amps. Thanks so much for the info.
Mike:
Thanks, I hadn't thought about all the other stuff on the PDB.
Your right, the temp is no where near the max rating, I was just worried that it would reduce the life of the regulator or was a sign of some problem
I might have caused when repairing the board.
I'll look around for a 9v wall wart in my giant pile-o-Smile. Since this is a pretty powerful regulator, I'm assuming an unregulated wall wart would
be acceptable as long as it's no-load peak doesn't go above the 36v that the datasheet says is max. Am I correct in this?
Weird thought/question:
If I were to use two 7805As with the V-Outs tied together to supply VDD on the PDB, would that reduce the current going through the regulators
and thus reduce the temp?
Update: I have a 1084 voltage regulator in my PDB, not a 7805a. I had both datasheets on my desktop and clicked on the wrong one
to get data for these posts. I apologize although it seems that the only major difference is the 1084 can handle 5amps with a max of
25v.
Post Edited (Ugha) : 5/15/2009 3:55:19 PM GMT
Paralleling the regulators is not a good idea, it would be better to arrange them in a cascode style. Short of that you can use a switching regulator for better efficirntcies.
Beau Schwabe
IC Layout Engineer
The current you can draw partially depends on input voltage. Switching regulators do not have this problem
Chris Savage
Parallax Engineering
Need to upload large images or movies for use in the forum. you can do so at uploader.propmodule.com for free.
I would look for another faulty component on Your Pro.Dev.Board. I checked the voltage from my wallwart (from Parallax) its output is just over 16volts open circuit. I measured 14.064 volts @ the DC jack on the P.D.B. with the switch "on".
I recently ordered the "data logger" from Parallax. I ran a 96 hr. test with it and 2 T/C readers on my Pro.Dev.B along with a BS2 in the stamp bay. The voltage Reg. ( LM1084 ) "this is the OEM REG. from Parallax" NEVER got hot. Just a little over room temp., Its dissipating over 9volts buy my readings.
I'll check My boards current draw and Reply the findings to this post.
_________$WMc%__________
The Truth is out there············································ BoogerWoods, FL. USA
