WAITVID causes hang
In the datasheet in section 4.10 is says "Failure to properly initialize the video generator by first starting PLLA will cause the cog to indefinitely hang when the WAITVID instruction is executed."
Is there any further information about this ?
I think this may be the cause of my video overlay board to hang with SOME propeller chips. The failure would occur as soon as they were tested. Changing the prop chip would fix the problem. So I'm thinking some of the PLL locked sooner than others.
Execpt it wouldn't hang indefinitely, it would hang until the CNT would wrap-around (50 seconds).
Could this be caused by this WAITVID situation ?
Bean.
There is a fine line between arrogance and confidence. Make sure you don't cross it...
Bean.
Do you have the WAITVID starting right after firing up PLLA?
A small time delay to let the PLL do it's thing would resolve this. Seems to me a quick test would be to get one of the known failed chips, insert the delay into the code and run them through.
Chat in real time with other Propellerheads on IRC #propeller @ freenode.net
Now, even if all of the above is true it will take 4096 PLLA cycles for VSCL cycle through it's initial 0 setting. This is also enough time for the PLL to stabilize, but this means it will take more time than just 4096 / PLL frequency seconds.
* I don't know if the PLL & VSCL are active for the other counter modes. Obviously, if CTRA is still 0 then the counter is disabled and WAITVID will halt forever.
** Other CTRA frequencies might work, but will be outside the PLL capture frequency. Again, if FRQA is still 0 then WAITVID will halt forever.
Composite NTSC sprite driver: http://forums.parallax.com/showthread.php?p=800114
NTSC color bars (template): http://forums.parallax.com/showthread.php?p=803904
