Waitpne question — Parallax Forums
Waitpne question
T ChapT Chap Posts: 4,260
edited 2009-05-15 02:06 in Propeller 1
Can anyone explain why the speaker is beeping in this loop?
I was trying to trace out by process of elimination why the loop that contains a lot of code keeps looping when conditions don't seem to be met for the waitpne to let anything through. When I got finished 'muting' all the masks to '0' as shown, it still kept beeping.
     repeat
       spk.beep(19, 8000, 20)
       waitpne(%10100_00000000_00000100, %00000000_00000000_00000000_00000000, 0)
    edited 2009-05-15 01:46
    When you mask all the input pins to zero, the result of the implicit AND can never be a non-zero value. Therefore a waitpne with any non-zero comparison value will never wait.
  • T ChapT Chap Posts: 4,260
    Thanks Phil, found the culprit.
