Power line modem with Serial Servo Controller?
I'm considering using one of these a power line communcations modem like this:
www.linksprite.com/product_info.php?cPath=217&products_id=3489&osCsid=c1fefd02eaa4a88c053db6c528933afc
with a Serial Servo Controller for a robotics project I'm working on. My robot is tethered to the base station with an power line umbilical cable, so being able to send RS232 data down the power line helps reduce the size/weight of the umbilical. Does anyone have any experience with these or can offer any advice on using them?
Next question: I have a pair of Parallax USB Servo Controllers that aren't being used for anything at the moment, how difficult / easy would it be to use the serial in on the USB PSC with the above modem? Or would I be better off buying a new Serial Servo Controller?
It looks like these modems support RS-232, but it doesn’t really say whether it supports logic-level signals directly. Assuming you’re stuck with RS-232 you could use the first circuit posted on the following link. It is for connecting an RS-232 serial port to the PSC (via its serial I/O, not USB). I hope this helps. Take care.
http://forums.parallax.com/showthread.php?p=640507
Chris Savage
Parallax Engineering
Chris Savage
Also, I will be using a total of 4 Sidewinder ESC's all controlled by the PSC. Do I need to disconnect any of the center (positive) leads on any of the ESC's servo connectors (as is the practice with RC radios)?
Thanks!
Chris Savage
