This totally bizarre code behavior has me baffled (DS18B20 w/ VGA)
Hi guys,
normally when I encounter a problem like this, I find a bandaid fix, suppress my curiousity·and just move on, but this one seems so weird that I can't let it go.
I'm reading a temperature off of one digital thermometer, a DS18B20, something I've done plenty of times.· Lately, though, I've·moved my display from a TV to a VGA.··After suffering many hours trying to find out why I sometimes see a correct temperature on the VGA and sometimes get a (very wrong) zero, I stripped my program down to a mini-version that continues to display a behavior I find totally bizarre.· In short, if I do NOT·ask the temperature reading loop to print SOMETHING (it doesn't matter what it is) to the VGA, then it appears that the DS18B20 will not be read at all.· Thinking that maybe the DS18B20 loop required a time delay of some sort, I tried inserting·some waitcnt functions, but that has no affect.· My bandaid fix is to have the VGA "print" something useless/harmless during the temperature reading loop - like a backspace or new line·- but why I must call up the VGA at all has me perplexed.
In my program, see the line (circa line 281) that looks like this:
Without that line, or some other command to the VGA, the temperature will simply read zero.
·Anybody think they can solve this mystery and dispell my suspicions that my Propeller has a little demon hiding inside?
thanks,
Mark
Watching the world pass me by, one photon at a time.
Post Edited (ElectricAye) : 5/11/2009 8:30:21 PM GMT
print_string(string("This line seems mysteriously essential..."))
thanks,
Mark
My Prop Info&Apps: ·http://www.rayslogic.com/propeller/propeller.htm
It's another way to say @addrs[noparse][[/noparse] i*2 ]
But are you sure that you really want to pass a pointer to the array element or the content of the array element?
thanks for taking a look at this.· I must confess that I am not smart enough to come up with the DS18B20 reading software myself; it was something I took from Micah Dowty's SpinOneWire-test.spin program last year and I've used it for a long time with the TV display and never had anything strange happen with it.· I have attached a copy of Dowty's original.
I agree that it smells like a memory stomp issue, maybe, but, as usual, I have no idea how one is supposed to map out memory to surely avoid such issues.· If it is a memory stomp, I'm baffled that adding a VGA command would prevent it: it seems to me that the VGA call would, if anything, make it worse.
thanks for your interest,
Mark·
To Bill and MAGI02,
I now have little doubt that what you're saying is true and I thank you for pointing this out to me. But how on earth is a poor wretch supposed to keep track of variables in such a way as to ascertain that this sort of thing can't happen? It seems like there should be a way to assure it can't happen other than shifting variable declarations and trial-and-error. This memory stomp issue has always left me feeling naked and vulnerable. Such a thing makes me feel like I'm working with a Jack in the Box. I wish there were a way I could map out the memory of my Prop so I could see that I'm in danger of having one variable stomp over another. Is such a mapping system even remotely possible???
thanks for shedding some light on my dull programming skills,
Mark
'' array_ptr = Pointer to 5,120 long-aligned words, organized as 80 across by 64 down,
'' which will serve as the tile array. Each word specifies a tile bitmap and
...and in your code...
cols = 80
rows = 64
tiles = cols * rows
LONG array[noparse][[/noparse]tiles/2]
Now my handy dandy calculator reveals that 80 * 64 = 5120. So I'm not sure why you are dividing it by two but I'd say you aren't leaving enough room for the tile array, and of course it's declared first before all your other vars so if it overruns it will stomp everything.
I'm sorry, but my documentation should have specified that that little tidbit was extracted from
VGA_Tile_Driver_Demo_2 from the OBEX.· Frankly, I have no idea what it does and I'm lost on how VGA works at all.· For a while it looked like I really had this VGA kluged together well enough to work, but as I continue testing things, I'm starting to have all sorts of Jack in the Boxes pop out and bite me.· Lord knows I've tried to understand how this VGA stuff works, but my usual complaint is that there are few comments in the OBEX code and I've never been able to find a VGA for Morons book that I could sit down and read.·
Now it looks like I've got the VGA driver 4-wheeling all over my variables.· I can't even get the simplest things to work right anymore.· I must have been out of my mind to've changed from TV to VGA.·
Rick
Hey, don't feel bad. The lack of comments in most of these drivers leaves me totally in the dark. It almost makes me feel better to see experienced people get confused by stuff like that, too. I'm not sure why so many programmers are biased against commenting their code. It's a cultural thing, I guess. ...Words. Hmpf! Who needs'em.
I am not an expert programer by by any standard but I use both VGA and Tv displays.My use of these are so far
strictly for displaying TEXT.I have not had much difficulty so far.
I use the VGA.Text and Tv.text objects.
So if you are displaying only text,use these objects - while trying to learn about the tile drivers.
Siri
