Need Some Help With Real random Class.. and random timer.
Hi i need to trigger 4 Pub's at different random times.
I tried the random object form the OBEX
but dint had to much luck with it. i need to start the Pub's randomly so the time span i need is from 30 sec. to 300 sec.
I hope some one has a good idea how to solve this, maybe i am blind
but i searched for it and count find any thing
Best regards Anubisbot
PRI Main_Loop
dira[noparse][[/noparse]11..0]~~
RR.Start
Time:= RR.Random
Time2:= RR.Random
Time3:= RR.Random
Time4:= RR.Random
repeat
If Time == 0
Small_1_Left
repeat until time > 5000000
Time:= RR.Random
If Time2 == 0
Small_2_Left
Time2:= RR.Random
If Time3 == 0
Small_3_Left
Time3:= RR.Random
Time--
Time2--
Time3--
Time4--
Leon
Amateur radio callsign: G1HSM
Suzuki SV1000S motorcycle
The random object generates a number in a range from 0 to ~4billion. As you do a lot of SPIN stuff inside of your loop this can take a while and I don't see any code that ensures the time being between 30 and 300s.
Time1:=30 + RR.Random & $FF···· ' would be a fast solution where the range is between 30 and 285 if that's fine for you
Time2:=RR.Random
Time2:=30 + Time2 & $FF + (Time2 & $F00) >> 8··· ' is randomly adding another 15, so the range is between 30 and 300, but it's a bit slower ... but hey, we talk about seconds ;o)
Now you sould use waitcnt to wait for seconds:
time:=0 CntToWaitFor:=cnt repeat CntToWaitFor+=clkfreq waitcnt( CntToWaitFor ) time++ case time Time1: small_1 Time2: small_2 Time3: small_3 Time4: small_4·As I used the case statement you should make sure that not two times have the same value.
