programming vss input
Hey,
I'm working on trying to get a 3 color LED to function. only problem is it needs 1 positve voltage and 3 neg vss voltages,
Is there a way to make this happen?
Here is the page for it.
http://www.radioshack.com/product/index.jsp?productId=3020765&tab=summary
basically, I need 1 positive voltage, and each light color has its own pin, the light runs off of 1 positive voltage, and 3 diff neg inputs,
please help.
i know i may sound stupid asking this question.
but, what does it mean when the light goes bright, then slowly dims???
when the tri-color LED is plugged into the homework board. it has 1 470ohm resistor plugged into 1 npn then into one neg leg of the LED. each one is on its own port. (ie p15 controled red, p14 controls green, p13 controls blue.) the red light starts bright then fades, when not using the controller stamp. just testing the cericut on the board, using the always on positive, the red does the same thing, using the battery (not going via stamp) using same setup. the red light of the LED did the same thing.
How about starting with what I suggested earlier.
It's usually best to start with something expected to work, then modify that.
Here is the Schematic of what i am trying to do, im needing help figuring out how to use the NPNs correctly, and also what Resistors i need.
I also still not sure how to use resistors properly....
any help would be appretiated.
Thank you all.
Post Edited (thinkgeek) : 5/13/2009 3:11:57 AM GMT
There are Wikipedia articles that show how a junction transistor works. Have a look at them and at the links from those pages.
I dont think they are MOSFET's... i have got it to work with a 9 volt battery. by itself. using a 150ohm then switch then npn then 1x150ohm for blue and green then 2x 150ohm for red. now, i'm going to try the basic stamp.
one more question, does anyone know where i can find how resistors actually work and how to tell where to use certain resistors and when....
thank you for all your help.
The resistor values I gave you were for use with a Stamp and it's +5V output. At 9V, the current will be nearly double that at 5V. It won't damage the LEDs at that current (close to 20mA each LED), but could damage the Stamp. You can't just use the same values under different circumstances and expect everything to work properly.
