New to Propeller
·Hello FolksI'm new to the Propeller and just going through the examples using the PPDB.
I have some PIC assembler, C and PIC Basic Pro experience, but am new to Spin/
I have inspected some of the Objects included in the Propeller Tool and have a couple of, probably simple questions.
I want to send a simple serial byte (or series of bytes)·and want to use the FullDuplexSerial Object.
There seems to be very little documentation on using these Objects ie max baud rate, how do I send a String verses a numeric value verses a single character. Does anyone have a simple example of including this Object.
Timothy D. Swieter, E.I.
www.brilldea.com - Prop Blade, LED Painter, RGB LEDs, 3.0" LCD Composite video display, eProto for SunSPOT
www.tdswieter.com
Leon
Amateur radio callsign: G1HSM
Suzuki SV1000S motorcycle
Tim
To send a string you simply use str(stringptr). To send a decimal number you use dec(value).
If you have problems, post your program here and you will get some help.
Leon
Post Edited (Leon) : 5/9/2009 5:49:37 PM GMT
Yes I jumped in and gave it a try and it worked.
I think I just need to play with the str and dec parameters. Once working at 9600 I will increase up. My max is usually 115,200
Should be possible with 5Meg Xtal and PLL X16
Tim
Leon
Post Edited (Leon) : 5/9/2009 6:09:01 PM GMT
· Home of the MultiBladeProps: TriBladeProp, SixBladeProp, website (Multiple propeller pcbs)
· Emulators: Micros eg Altair, and Terminals eg VT100 (Index)
www.tdswieter.com
I think I was a little overwhelmed with the new hardware, and software at first but I am now sending serial strings and decimal numbers at 9600 to 115200 baud - no problems. I have been used to working with PIC's and the ever increasing use of hardware USARTS ADC's etc with each new part. In some ways the Propeller is like going back to the early PIC days where everything was done in software except most of the routines have been written for you. I just need to get used to some of the way Spin does things. Then move on to try some assembly.
Thanks for all the help
Tim
Yes, ViewPort allows you to transfer data at up to 2mbps. The FTDI chip used by Parallax supports 3, 2, 1.5, 1mbps and many slower baud rates. I did get 3mbps working, but it's a big pain. At 80MHz, the 2mbps rate is much more doable.
Hanno
Download a free trial of ViewPort- the premier visual debugger for the Propeller
Includes full debugger, simulated instruments, fuzzy logic, and OpenCV for computer vision. Now a Parallax Product!
