Problem with hot pin 11 on propeller proto usb board
I have an led attached to pin 11 on the the proto usb board that stays on constant. I even ran a simple blink program on another pin but pin 11 stays on.
Is pin 11 used for something else?
The program I am trying to run is the "magic compass" program I have been working on that is now a complete mess (mostly working but a mess). So I loaded the simple led blink program using pin 4 (just to be sure the program wasn't the problem) and the led on pin 11 still stays on.
Now I have more pins tied to leds that are working as expected (pointing in the direction that I want according to the program), but I wonder if using them is the problem.
I am using pins 11 to 26 to light directional leds around a compass face and pins 5 to 10 to light the distance to target leds.
command if that would at least turn it off and I would just use another pin.
Are you talking about Pin 11 or P11? depending on which package you have it would be P10 on pin11-LQFP, or reset on DIP
