High speed data grabber?
I need an interface to existing legacy equipment, the requirement being capture and store a 5 bit word when a sixth bit 'strobe' occurs. The strobe bit high duration is about 0.5uS, and the interval between strobe pulses is a little less than 20uS. There are only about 50 or so words in a burst of this data, and many seconds elapse between bursts.
I have decided to try this most excellent Propeller Chip for this application, if it is able. I would appreciate any comments and tips!
Dave KI4PSR
Dave KI4PSR
I will try what you suggest,
Dave KI4PSR
